In the shop at Pelican
Jared at Pelican Parts's Avatar
Random Cold Start Problem
Been having a wierd one lately....
83 SC..
about once a month it has a problem starting cold, where it will go, but you have to floor it, and it maybe gets to 2000 RPM, but it runs really rough and backfires like crazy for about half a minute, then it's fine...
Only does it like once a month and seems to only happen on damp mornings....
Old 05-26-2005, 10:03 AM
Wow, no one has any ideas....
Old 05-26-2005, 11:48 AM
B D B D is offline
B D's Avatar
Sounds like a cold start valve or whatever they call it on a SC. I bet if you were in a colder climate it would happen more than once a month.
68 911L
Old 05-26-2005, 11:51 AM
So what, is it leaking or is it simply not functional?
Old 05-26-2005, 11:55 AM
GOT TURBO..
MobileWrks's Avatar
Also, if you have to floor it, thats a problem. Your not suppose to give a porsche throttle on start up. hook up gauges and check pressures. Thats alway a start...
Old 05-26-2005, 07:57 PM
Designer King
Paulporsche's Avatar
Sounds like it's probably your WUR. As previously said, check control pressures, especial Cold CP.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-27-2005, 09:48 AM
It only happens maybe once a month,
When i said full throttle, i meant to keep it running otherwise it just dies...
Every other time, she fires up right on the first time, purring...
Old 05-27-2005, 10:14 AM
