tubwreck's Avatar
Front wheel play: Up & Down, not side-to-side
On my '88 carrera, I notice that both front wheels have slight but noticeable play in the vertical axis but none in the horizontal axis. The play is the same whether the wheel is loaded or not. I cannot see any movement in the balljoint (unloaded), the car drives fine and makes no odd noises.
I am assuming that this is not a wheel bearing (no side-to-side play). What it "feels" like is play in the strut or between the strut and the shock insert. It's also wierd that both wheels have it.
Anybody else notice this? I couldn't find a spec in Bentley for wheel play.
TIA
Old 05-30-2005, 03:49 AM
Metal Guru
911nut's Avatar
Sounds exactly like wheel bearing play. Re-pack your bearings and re-set play per the Bently manual.
Paul B.
'91 964 3.3 Turbo
Port matched, SC cams, K27/K29 turbo, Roush Performance custom headers w/Tial MV-S dual wastegates, Rarlyl8 muffler, LWFW, GT2 clutch & PP, BL wur, factory RS shifter, RS mounts, FVD timing mod, Big Reds, H&R Coilovers, ESB spring plates- 210 lb
Old 05-30-2005, 04:56 AM
Pat S's Avatar
I had this and it took me hours to realize that it was a slightly loose ball joint. I must not have tightened the giant nut on the bottom tight enough when I rebuilt the suspension.
Pat
Current: 07 S4 Avant, 06 Volvo S60R
Sold: '74 911, 01 986, 93 Volvo 240
Old 05-30-2005, 05:31 AM
Designer King
Paulporsche's Avatar
As you indicated, usually if, when pushing @ 3 and 9 o'clock there is movement, it's the bearings. 6 and 12=other, such as suspension or ball joints.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 05-30-2005, 05:36 AM
I have noticed a similar issue with mine. I knew something else was the issue when after tightening the bearings past the point of being able to move the washer that something else was wrong. For referance the ball joints and wheel bearings are pretty new. I pulled the rotor off and inspected the spindle shaft, and low and behold there was a small step worn on the underside of the shaft where the outer bearing rides, and the area where the inner rides looked pretty crappy (like the bearing had spun) but there was no step. I need a new strut unfortunately.
Chris Bunker
78 SC
Old 05-30-2005, 08:55 AM
kstylianos's Avatar
Send a message via Yahoo to kstylianos
I've seen this before w/ Boge struts. Thought it was a loose bearing, but happened to be the insert retaining nut at the top of the strut, under the dust cover.
Charlie Stylianos
1982 SC Targa
www.Dorkiphus.com - (The Land of the NoVA/DC/MD Porschephiles)
Old 05-30-2005, 09:31 AM
If after checking all these things....take the wheel off and inspect the spindle. There may be 12 and 6 o'clock wear not evident at 3 and 9. Mike it at 90 degree intervals and see.
If so, probably time for a new strut housing. Or....build up and regrind the spindle back to spec as equal diameter at all 4 clock positions.
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 05-30-2005, 11:41 AM
I had the loose nut problem on the other side of the car before. Even after it was tight, I'm not 100% happy with the amount of play.
Wil is it really possible to repair the spindle by building it up and regrinding? Who does it? Cost?
Chris Bunker
78 SC
Old 05-30-2005, 12:37 PM
I haven't done it but have heard it can be done.....
Wil
Wil Ferch
Old 05-30-2005, 03:37 PM
