Sports Purpose 911 Driver
mjshira's Avatar
Unhappy wiper challenge - anyone have an idea/
so last night, in a major rain, my wipers stopped working. I was driving the future Mrs. back from the airport about 100 miles from my place.
good thing I have a habit of using rainx!
anyway, I checked the fuse, the fuse connection and both are fine, also.
I have power to the switch also.
fuse panel connections are good
Before I go and remove the fresh air blower to get to the wiper motor has anyone got an idea about what I should be looking for?
The car has been very well maintained but the wiper motor is probably 30 years old now...
James Shira R Gruppe # 271
1972 911 Coupe 3.8 RS ‘nbr two’
1972 911 Coupe 3.2 TwinPlug MFI 'Tangerina-Jolie'
1955 356 Pre A Coupe ‘old red’
1956 356A Emory speedster build in progress
Old 06-03-2005, 09:59 AM
Remove the speedo and/or clock and try jumpering the wiper connections directly. When I got my '77, the wipers would blow the fuse in the first position, but not the others. Turned out the relay had been mis-wired, and I was able to fix it from the passenger compartment.
Old 06-03-2005, 10:04 AM
I would rather be driving
jpnovak's Avatar
James, You will be able to access the wiring points to the motor behind the speedo and clock. I would look there to see if you have voltage. If so, the motor probably gave up. you could try to turn them on and force the wiper by hand to see if its "stuck'. Another thing to check is that hte linkage is not binding.
Old 06-03-2005, 10:05 AM
mjshira's Avatar
thanks guys, I will check that.
I was manually triggering them when the suddenly wouldn't work? strange huh. I will pull those bits and see what that gets me. The urgency is that if I can't fix this I'll have to take my old truck to run her back the airport and that for 250 mile round trip ain't fun! too slow, too much fuel.
anyway, let me examine that area and see what I find. BTW what does a wiper motor run these days anyway?
Old 06-03-2005, 10:08 AM
mjshira's Avatar
it's fixed!!!
so I removed the gauges as recommended (thx Jamie)
and before I could even get the power tested grounded and ready I saw the ground plug at the wiper motor and noticed it was not connected
it's nice when a job is that easy! thanks for the tips fellas. while I had the tools out I mounted some new bling to the decklid. Not sure if I am sold on this look but you guys let me know what you think.
when the new engine is in a 3.6 emblem will be added to the free space towards the right side.
Old 06-04-2005, 03:59 PM
mjshira's Avatar
if anyone has an idea on how I could get the grill in this decklid chromed please let me know.
Old 06-04-2005, 04:00 PM
kqw kqw is offline
Great you found the issue...Don't ya' just love it...
Also, I noticed that you mounted your badges directly over the center of the grill. Careful not the inhibit too much air flow to the A/C condensor under the grill. Many folks mount badges to the upper right or left...minimizing the interuption of air flow.
The Fox
Carrera
Old 06-04-2005, 04:49 PM
mjshira's Avatar
thanks. I don't have a/c so I don't think this should be a problem. Also, since it is a 964 tail I can deploy it and get more air
Old 06-04-2005, 04:53 PM
kqw kqw is offline
Don't tell me that you retro'd a 964 tail. How in the hell did you do that...Don't answer that....I know it was quite involved and I'll search the threads....
thanks
The Fox
Carrera
Old 06-04-2005, 05:00 PM
mjshira's Avatar
go for it man, its a great up grade. check out Thom F's page.
Old 06-04-2005, 05:28 PM
mjshira's Avatar
if you look close enough you'll see my third brake light
lateapex911's Avatar
I love that R Gruppe badge! It look so....."right"! I wanna be in the R Gruppe!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 06-04-2005, 05:46 PM
mjshira's Avatar
send a note to Cris.
thx 4 the kind words
Old 06-04-2005, 06:19 PM
kqw kqw is offline
You're Killing me, You're Killing me....(Hank Stram..KC Chiefs)
Great info..I'll check it out..
Thanks again
The Fox
Carrera
Old 06-04-2005, 11:17 PM
mjshira's Avatar
here is a link to his site
http://www.rennlight.com/thomn8r/
Old 06-05-2005, 07:12 AM
