WilliamJ's Avatar
Voltmeter? for 911
Tell me what you think: 1985 911
Left the ignition key on overnight, wouldn't crank over the next day but lights would light up dimly. Charged the battery, and when I tried to start it, it wouldn't crank.
Voltmeter read 8 volts.
When I went to warranty the battery out they told me that the battery was gone but that also the alternator was not putting out anything.
They're installing one now.
My question is: Has anyone permanently hooked up a voltmeter or ampmeter so you can tell the status of your charging system?
Speedo, Tach,3 oil guages but no Voltmeter, whats up with that?
1985 Carrera
2000 Tacoma TRD 4x4 Supercharged
1984 Harley Shovelhead Wide Glide
Old 05-31-2005, 05:53 PM
Somatic Negative Optimist
Gunter's Avatar
That's a strange coincidence that the alternator should fail. However, it is possible that the alternator got overloaded on charging with a very low battery. I istalled a VDO voltmeter seperately, but it isn't needed; the alternator either charges or it doesn't.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD!
1995 seafoam-green 993 C2, LSD, Sport seats.
Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Old 05-31-2005, 06:25 PM
jbripps's Avatar
Hi,
I have a voltmeter built in to my radar detector. It's the passport 8500, and no, this is not intended to be comparison post. Anyhow, if it has one advantage over the "others", there is a voltmeter that always is displayed, if you select that option. It does not interfere with radar detection, and bogey counter. Detection is displayed smaller vertically rather than horizontally.
Anyhow, I LOVE this feature, as it will warn me when my volts are low. I have had a bad alternator, twice, so I like the piece of mind. Plus, you can see what the car eats up as you use options, like headlights, etc., kinda interesting.
It is very handy and for the most part accurate. If voltage gets too low, or below 11 volts, then it will sound. Also, it will sound if too high. It's a pretty damn good radar too. Ok, enough of that.
Regards,
Jon
'85 Targa (recently acquired by Coollx)
'02 Carrera 4S (holy moly...I'm in heaven....in the snow too)
'06 BMW 325i (gone and forgotten)
'03 Honda Odyssey (more dings every day....thanks wifey)
Old 05-31-2005, 07:02 PM
never ending projects
niner11's Avatar
built this last year after I had some alt probs.
Old 05-31-2005, 07:49 PM
Administrator
Jack Olsen's Avatar
Old 05-31-2005, 07:58 PM
niner11's Avatar
Two good links:
http://www.lascarelectronics.com/products.cfm?STOCKNO=EMV%201200&CFID=35578&CFTOKEN=60812033
Old 05-31-2005, 08:09 PM
Senior Member
Do a search on Pelican on the 911 tech board. This has been discussed many times before and no reason for a new thread.
This is a good start. I used one like Jack mentioned below until I installed one for good.
In-line voltmeter on dash? Suggestions?
JoeA
Old 05-31-2005, 09:30 PM
Administrator
Jack Olsen's Avatar
There are also voltmeters you can plug into the cigarette lighter.
Old 05-31-2005, 09:31 PM
WilliamJ's Avatar
Thanks guys!
1985 Carrera
Old 05-31-2005, 10:48 PM
Recreational User
DarrylD's Avatar
Here's my voltmeter:
I had an alternator go out in Tofino, British Columbia... look at a map an you'll understand why there's a voltmeter in my dashboard now!
Old 05-31-2005, 11:25 PM
Why did you edit the other link out? Could you put it back in or email it to me. I came back to write it down and poof! Gone
Scott Clevenger
1989 BMW 325ix 190K
1981 911SC 110K miles
http://www.pelicanparts.com/gallery/clevy70911T/
Old 06-01-2005, 03:57 AM
And here is mine:
Peace, Ron
www.ronorlando.net
78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk
Own a gun and you can rob a bank , own a bank and you can rob the world.
Old 06-01-2005, 05:53 AM
Friend of Warren
Here's mine:
Kurt V
Old 06-01-2005, 07:09 AM
randywebb's Avatar
For the real gauge-ophiles, a storage oscilloscope would be the ticket...
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-01-2005, 10:43 AM
wait a minute.. There is a 2.25" dia "storage oscilloscope" available?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-01-2005, 10:49 AM
yeah, Kurt.. you posted that sweet tach/voltmeter picture after I had already installed mine in the console. One of these days I would like to go that route and use the voltmeter hole in my console for a AFM. How much was the the gauge or mod?
Peace, Ron
www.ronorlando.net
Old 06-01-2005, 01:09 PM
randywebb's Avatar
"2.25" dia "storage oscilloscope"....
- Well now, look which fish the hook trawled up....
- You could get one of those new fangled LCD scopes - Tek has several. Then put it up behind a 2.25" ring cutout and adjust the display size to make it fit...
So.... ?
Old 06-01-2005, 01:55 PM
[B
So.... ? [/B]
so I googled Tek and got their home page.. then on the left is a line of not necessary info..
what next?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 06-01-2005, 02:35 PM
randywebb's Avatar
Dunno - get their paper catalog? used to be as thick as a bible...
But run with it Ron... It's perfect in some way...
Old 06-01-2005, 04:35 PM
Early_S_Man's Avatar
Porsche Crest
Guys,
Here is [probably] the smallest CRT-type Tek scope ever made ... 1992 - 93 vintage, less than 6" wide, less than 12" deep, runs off 12 - 18 Volts DC, and has two PC software packages [one free download, the other was purchased with scope] for remote control, display, and analysis [DOS] and uses one of those ancient serial ports & cable for comm. You can find them occasionally on eBay. It won't replace a 7854, but it fits in a briefcase and is very lightweight and easy to use!
Probably could be fitted to a console or custom-built console replacement! Even using a laptop for display gives an amazing amount of detail in the traces and CRT-readout data, and a full 21" monitor is mind-boggling! I can imagine some remote switching of inputs to various sensors and systems to monitor alternator/VR status, ignition triggering and output to both coil and plugs, tach drive pulse stream ... even gauge sensors and activity!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 06-01-2005, 11:42 PM
