shrouded's Avatar
Send a message via ICQ to shrouded Send a message via AIM to shrouded
Odd Throttle Response
I noticed something odd last night, driving for the first time since my first engine drop.
There are situations where applying throttle will raise RPM, without seeming to get any additional power to the wheels. For instance: cruising at about 2500rpm in second gear. If I gradually apply more throttle, everything will work as expected clear through to redline. if I get on the throttle hard, however, at around 3000rpm the motor will to run up, but I will feel little or no additional power at the wheels. I just keep cruising at the same speed, even though I may end up turning ~6000rpm. In this situation if I let the rpm drop back down a bit and reapply throttle slowly, the car will behave normally again.
This is coming after an engine drop where the transmission stayed in the car. An oil return tube, thermostat o-ring, and oil pressure switch were all replaced. What am I missing?
1982 911SC - Metallic Rosewood
Old 06-10-2005, 07:08 AM
Designer King
Paulporsche's Avatar
Could it be the clutch?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-10-2005, 07:13 AM
Go Speedracer, go!
SpeedracerIndy's Avatar
Did you adjust the clutch correctly? It sounds like the clutch is not fully engaging.
1981 SC ROW Coupe
Old 06-10-2005, 07:17 AM
shrouded's Avatar
Hmm... good call... I don't know how to adjust the clutch correctly, so it is unlikely I stumbled on the right way to do it. Are we talking about the adjustment screw on the lever, or something else?
Old 06-10-2005, 07:25 AM
Unregistered
sammyg2's Avatar
Don't drive it anymore until you get this resolved, you could be burning up your clutch disc.
Get a hayne's manual and follow the procedure, it is fairly involved the first time.
You have to remove the cable, set a clearance, then re-install the cable and adjust the cable until the clrarance is changed slightly. I can't remember the measurements off the top of my head, something like .040" to start and then reduce it to .030" with the cable.
Old 06-10-2005, 07:58 AM
shrouded's Avatar
Excellent. I assume you are referring to the setting the adjustment screw, as shown here.
Wayne's guide ( here ) has that at 1.2mm, which should be just a bit more than you are suggesting. Now I just need to find something of the correct thickness (or a tool, as shown above), I guess.
Old 06-10-2005, 08:53 AM
Unregistered
sammyg2's Avatar
Yep, that's it. Like I said I wasn't sure about the measurements, it's been a while and I have CRS
You have to set that clearance with the cable disconnected and they install the cable and adjust until the clearance is reduced by a certain amount.
Feeler guages as shown in that picture are relatively cheap, easy to find, and a must have if you are going to be working on your car. I bet you can find a decent set for under $10 and they will last forever if you take care of them and don't let them rust.
Old 06-10-2005, 09:32 AM
