I had the same problem with my 84 Targa. After following kuehl's diagnostics I bought the Radio Shack relay (paid $6.29 + tax, P/N 2750226) and swapped it with the one in my smuggler's box, per ruf-porsche. Problem solved! Thanks much for all the help.
84 Targa
Old 06-21-2005, 05:25 PM
vesnyder's Avatar
Send a message via AIM to vesnyder Send a message via Yahoo to vesnyder
You won't believe this, but I put the whole thing back together just so I could drive it and it works!! I did check the smugglers box and could not find the relay - can somebody post a photo or describe where it is? You guys are talking about the smugglers box inside the trunk? I checked around in there and could not locate a relay?
Vance
'83 SC Cabriolet - The "Matrix"
'73 914 - "Spicy Mustard" - SOLD
Old 06-21-2005, 07:00 PM
ruf-porsche's Avatar
Another problem solved on the Pelican Board.
Old 06-21-2005, 07:33 PM
Here's a pic. showing the Radio Shack relay in place in my 84 Targa. It's the black plastic component on the outside wall of the box with red, yellow, red+white, and black wires attached. It's held in place by a nut and stud that's on the outside wall of the box.
84 Targa
Old 06-21-2005, 08:02 PM
kuehl's Avatar
Sounds like it "may" have been a lose connection. But, great team work!
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 06-22-2005, 05:28 AM
vesnyder's Avatar
Thanks a lot guys - the photo really helps. I wonder if it may have been the power wire - the connection is fairly corroded. This board rocks!!
Vance
Old 06-22-2005, 05:46 PM
bigchillcar's Avatar
dmk,
what exactly was the problem you were having that you substituted the existing a/c relay in the smuggler's box for one from radio shack? periodically when running my fan on highest speed, everything will quit - fan and all - is this similar to the problem you were experiencing?
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 06-22-2005, 09:47 PM
Hey Ryan
Does the a/c quit or just the fan? Fan for the evaporator receives current from the relay in the smuggler box. There is also a fan resistor that control the speed of the fan. Cheapest fix will be to replace the relay from rat shack. Actually I found a seller that sells Bosch automotive relays for under 2 bucks, but shipping will be the killer on this deal. http://www.partsexpress.com.
Old 06-23-2005, 06:59 AM
ruf,
hey that's great! the fan just suddenly quits..i have to turn it to a lower setting and then after a couple of minutes it turns itself back on. thanks for the cool tip..
ryan
Old 06-23-2005, 08:32 AM
kuehl's Avatar
Check your shunt resistors located in the RH side plenum intake,
below the passg. side foot board. As I recall they have bimetal
contacts to break the contact when they over heat.
Kuehl
Old 06-23-2005, 09:09 AM
Yellowbird RS's Avatar
AC Not Working - HELP?
it has never done it and never will
X/A
Old 06-23-2005, 11:55 AM
here's a hot data point for ya: sunny, 100 degrees in little rock..thermometer said my car with windows cracked open, sitting in the shade turned off was 105 degrees. driving on the highway for an hour at 75 mph (oil temp 220-230, no aux cooler) the cabin temp never went below 90 degrees with a/c on max and full fan. when temps climb much above 90, there is little comfort in my car. i run freeze-12, stock deck condenser, stock r/d, stock non-barrier hoses, stock evaporator, sanden compressor. system was charged about a month ago..i either have a leak or my current system is simply too taxed at 100 degrees ambient.
ryan
Old 06-23-2005, 03:56 PM
bigchillcar,
It was running fine on fan setting 2 or 3 and just quit totally, and wouldn't restart.
It's almost as hot here in StL. I haven't measured the temps. but the a/c which is working as well as ever makes it tolerable, no better.
84 Targa
Old 06-23-2005, 04:52 PM
dmk42,
yeah i hear ya there..tolerable describes mine most of the time, but 100 degrees is just too much unless i upgrade to a more efficient condenser (or two WITH fans), barrier hoses, new r/d or procooler. a 'cool grand' would probably make my car tolerable up to 100 degrees..
ryan
Old 06-23-2005, 04:58 PM
That is one of the reason why I brought my PORSCHE. The LOTUSES were just intolerable to drive when it got over 80 degrees. When it gets intolerable in my PORSCHE I just drive the Bimmer Touring (they don't call it a wagon), or the wife Audi. The Audi is cold enough. to hang meat in there. Who says Germans can't design a decent A/C system for a car?
Old 06-23-2005, 08:01 PM
apparently most can who begin with a front-engined, water-cooled car design..
ryan
Old 06-23-2005, 10:06 PM
