Factory sealant removal at top of front struts
Anyone have a good system for removing the factory sealant from the top of the front struts under the hood?
This stuff is black and tar-like. Figured I ask before going at it with something too strong, etc. |
just use a scraper or razor blade for the big stuff. It should come up fairly easy. I don't recall using and solvent or anything like that to do the job when I replaced my shocks.
Tony G 2000 Boxster S |
Cymru am Byth
Hot air gun and a variety of scrapers
1986 930 (Gone but not forgotten) 1995 993 (Should Never Have Sold it) 2007 BMW 328Xi Sport Wagon 2005 Lexus GX470 Offroader Julian Williams |
I did mine with a stiff cup type wire brush on an electric drill.
It's effective, but sprays alot of debris. If you use this method,be sure to cover the surrounding area with a drop cloth or something similar. |
First chip away most of it, and then remove whatever remains with petrol.
'70 911T (AKA Bottomless Pit) - Undergoing restoration '13 Audi A4 1.8T - Surprisingly fun means of getting to work |
I just chipped mine off.
Great feedback, guys. Thanks very much.
1979 911SC 1978 911SC Euro Instagram: collierbrands |
Why remove it?
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
My tire guy pointed out that to get in there for an alignment I'd need to remove the stuff citing access to bolts, etc. He suggested that my car had never been adjusted up front. It's far from his first 911, so I took it at face value. Thoughts?
The project can be a little neater if you first "define" the edges of what you want to remove, with an X-acto or utility knife.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
DP935 member
I have used ice to freeze the larger pieces and pry with a small screwdriver and it comes off real easy. Then I use a roloc gasket remover to clean up.
Porsche Slantnose M505 M506 group on Facebook. https://www.facebook.com/groups/719995181372494/ |
