S man you are a fantastic asset.
Found this thread today and have not yet read the vast detail, so this may be a silly question. but here goes. I have several six pin units which are faulty. Have you any suggestions for a set up for bench testing these six pin units out of the car when I have "repaired them". What precautions do I need to take if I run the six pin unit on a bench DC power supply in order to test it? I can think of several ways of doing it but can you suggest how I can best supply the input pulse to point 7 to test the unit as in the car, can I leave the output open do I need to fit a coil to the output end or can I load the unit with a ballast resistor?. |
Hope that helps, Ingo |
"Have you any suggestions for a set up for bench testing these six pin units out of the car when I have "repaired them"."
Actually, the testing is really the 1st step prior to repairing. If one lacks the testing knowledge, the "repairing" becomes questionable. |
Just as an example, please find hereafter a picture of the test bench I am occasionally assembling (at home !) to repair 3 or 6 pin units.
Attached is also a picture of the modified plug used for the test. The modification is done for increasing the gap to about 6 mm (0.25 inch) in order to reach at the atmospheric pressure about the same disruptive voltage as in the cylinders. I am using a pulse generator for simulating by RC derivation the output of the pickup coil for 6 pin units, and a simple square wave generator for testing 3 pin units. About the power supply, if a battery is not used it is to be noted that, due to the highly inductive equivalent load of the internal flywheel converter, some energy is sent back into the power supply during a part of the 3 kHz cycle (I have measured up to 4 A peak !), so that it is useful to connect a large electrolytic capacitor in parallel at the output. I use a 470 µF cap. for that purpose.http://forums.pelicanparts.com/uploa...1189009281.jpg http://forums.pelicanparts.com/uploa...1189009476.jpg |
"I am using a pulse generator for simulating by RC derivation the output of the pickup coil for 6 pin units, and a simple square wave generator for testing 3 pin units."
Actually, a simple sine input is all that's needed for the 6 pin with an added transistor switch for the 3 pin. Also, to avoid CDI damage or heart failure, the spark plug needs to contact the CDI case, i.e. the coil ground terminal. "some energy is sent back into the power supply during a part of the 3 kHz cycle (I have measured up to 4 A peak !), so that it is useful to connect a large electrolytic capacitor in parallel at the output. I use a 470 µF cap. for that purpose." It all depends on the output impedence of the power supply, i.e. its characterics. |
This instability disappears with a sharper input signal. Quote:
"but for observing the triggering of the SCR the slope of a sinusoïdal signal is not fast enough for not to be perturbed by the interference with the 3 kHZ frequency of the converter. "
Do what???????? Check the signal from the distributor pickup, it's basically a sine wave with distortion, i.e. harmonics. And what's the purpose of the Schmitt Trigger, i.e slow rising and falling slopes while cranking. Use a higher freq sine wave. The output capacitance of a power supply is a factor of its output impedence, i.e. the dynamic or A.C. properties. Some junk power supplies don't have ANY output capacitors, and thus have poor dynamic response to LOAD transients. |
....time to break out the popcorn :D
Wow I started something here.
Lets not get to het up it's only a bit of electronic kit. To put the record straight I am a domestic TV audio engineer with a fully fitted workshop for LCD PLasma DVD and audio products, so I have the kit and well know both my limiuts and the limits of power supplies etc, I have enough info from this and other threads to sort the rig I need and that is what I asked for (thanks s man jmchrist and impmad2000 here and else where). gulf blue rsr is my son who I am helping out with the problems with cdi units. What strikes me so far is that for the asking there is a load of information on these units and with some luck and a lot of reading I should be able to sort them but I cannot see for the life of me why these units cost so much to repair else where. Thanks to all for your input all I need now is a supply of parts and again with the help of these threads I think will be able to souce them also. |
When all else fails, order a rebuilt unit from Pelican Parts!
Nice one folks, burnt the midnight oil last night and managed to get two of the units up and running, couple of zenners and a dry joint, not easy to find but we got there.
on wards and up wards as they say.;) |
Congrats to Gulf Blue RSR, Sr. on the repair!
<b>Bad connections, to include bad solder joints, both on the printed circuit board and to the 'flea'clips where the 15 or 17 wires attach, and Faston connectors of the loose and corroded variety ... are the most common failure mode for the Bosch CDI units!</b> I had originally intended to confine discussions of the 6-pin units to the following thread, but it doesn't really matter to me ... dial-up users may have to suffer, though! http://forums.pelicanparts.com/showthread.php?t=203100&highlight=cdi+documentatio n I normally use a Tektronix RG-501 Ramp Generator in a TM515 mainframe to trigger 6-pin units. The manual can be downloaded here: http://www.bitsavers.org/pdf/tektronix/tm500/070-1352-00_RG501_Jul72.pdf Almost any function generator, time mark generator, or pulse generator could be used to trigger the 6-pin Bosch or Permatune CDI units, but I already had the ramp generator ... Here is a thread about a DIY CDI project that may be of interest to some out there who like the idea of a newly-constructed spare CDI unit ... http://forums.pelicanparts.com/porsche-911-technical-forum/353053-diy-cdi-kit-1997-silicon-chip-magazine-article-oz.html?highlight=diy+cdi Here are a couple of new revised schematics to include all three of the lumped suppression resistors in the coil output circuit: http://forums.pelicanparts.com/uploa...1189151981.jpg http://forums.pelicanparts.com/uploa...1189187000.jpg |
What is the load over the (R12) 15R ?
100 mA ? bob |
Bob,
With a nominal 14 Volt input from the alternator ... it is easily less than ~ 70 mA with T2 fully conducting. |
Warren I have a 3pin Box which has an R4 but not a R12 & Diode D8.
What year was that? Bob |
Bob,
1973 was the only year I know of that still had R4. Can you post the datasheets of the AEG SCRs here? |
The R4 resistor was used on all the late 3 pin CDIs until the 6 pin CDI
to reduce the susceptibility to input (#15) noise level, e.g. alternator, fans, RF ignition, & etc. |
Hello so this is a 73 CDI, the R4 is a 270R resistor.
It is placed between W1A & R5. http://forums.pelicanparts.com/uploa...1194074727.jpg Regards Bob |
Warren
W stands for "Wicklung" which english word is winding E stand for "Ende which is end A stands for "Anfang" which is beginning.... Bob |
Dear all,
it took me a long investigation for these datasheet. I like this forum and that why I post these TxxN x00 COB M datasheets. The rise time is 2 micro seconds The closing time is 50 micro seconds. So the RIAs series does not meet these values. http://forums.pelicanparts.com/uploa...1194267336.jpg http://forums.pelicanparts.com/uploa...1194267361.jpg Regards Bob |
| All times are GMT -8. The time now is 08:10 AM. |
