-   -   History of Bosch CDI ... toubleshooting info, parts list changes, and schematics ... (http://forums.pelicanparts.com/porsche-911-technical-forum/226517-history-bosch-cdi-toubleshooting-info-parts-list-changes-schematics.html)
oldewurtel 11-25-2007 10:11 AM
Dear all,
I´am new in this board and therefore I want to give a short introduction of myself:
My name is Kassen Oldewurtel and I live in the southern part of Germany (in the near of Stuttgart, as you know from BOSCH, PORSCHE and of course Daimler now w/o Chrysler).
I own a ´87 3.2 l 911 convertible and a car for "normal use" (1.9 l Audi A4 Avant TDI)
As I do all maintance on my cars by myself, I was asked to repair a CDI Box BOSCH "0 227 200 001" from a collegue of mine.
Due to a wrong cabling the SCR was gone "into the semiconductor heaven".
The original equipped type (AEG T6N500COB) is obsolete and not longer available.
What is the suggested substitution with identical (or better ;)) electronic and mechanical (M6 stud) figures??
I took the TIC126N (appr. $2.00 each) in combination with a selfmade (turned and milled) adaptor.
But this is a rather complex solution (pls see picture):D:D
Regards
Kassen
http://forums.pelicanparts.com/uploa...1196013979.jpg
HKZ Bob 11-25-2007 11:11 AM
Hello Kassel
do you like to use OEM design or the T-220?
Use a 2N6509 as a T220 replacement
Bob
oldewurtel 11-26-2007 10:39 AM
Hello HKZ Bob,
thanks for the reply,
I would like the OEM Design with the M6 stud.
Do you know a supplier or distributor for this part?
Regards Kassen
HKZ Bob 11-26-2007 11:13 AM
Go to http://www.rsonline.de
Look for Thyristor 25RIA120M.
Order no. 395-2869
Regards Bob
ischmitz 11-26-2007 11:19 AM
Kassen, that is a funny and ingenious design. But why bother to get an M6 style device in the first place. You could simply mount the TO220 housed device instead. Finding a TO220AB housed device with isolated mounting fin make it even easier.
Bob's suggestion is a part readily available in the U.S. but the TIC126 series seems equally suited. I can seem to find it from the U.S. suppliers but I remember that the TIC series is used in Europe quite often. TIC106 was what was used in old equipment for light controllers. The TIC126 seems to have all required ratings to surpass the original AEG device.
As an interesting side note the TIC126 is listed on Conrad's website as an International Rectifier part. However, I don't think IR makes it.
Does your box work after you put the TIC126 in?
Cheers,
Ingo
ischmitz 11-26-2007 11:39 AM
Order no. 395-2869
Regards Bob
won't work - ask me how I know......
oldewurtel 11-26-2007 12:05 PM
Hi Ingo,
I tested the device on my workbench w/o ignition coil (it´s still in the car and therefore 35 km away....).
I used a resistor (180 ohms) instead and looked at the output with a DSO.
The box sounds terrible, but I think that´s normal :D:D.
I was completely suprised to find the Test Manual and a (selfmade) circuit diagram in this board. I am able to see the red illuminated "BOSCH" sign in Stuttgart/Schwieberdingen from my kitchen window, where this box was developed, but no chance to get any information about this old stuff :confused:.
The final test (in the car) is next week and I`am looking forward to this test (with TIC116 or TIC126). The TIC126 will arrive tomorrow.
Greets Kassen
Early_S_Man 11-26-2007 06:05 PM
Greetings, Kassen, from Texas!
Bosch test documents specifically say not to use a resistive load on the CDI unit ... only a proper coil!
jmchrist 12-07-2007 01:38 AM
Sorry for this late answer.
I have used a 2N692 as a replacement (with the correct TO-48 case).
I did it only once without problem even though this model is not specified for Toff.
The 2N692A is specified with a Toff of 15 µs, if you can find it.
Hope this help.
chb 03-15-2012 09:35 AM
hi at all!!
I am new here and I hope you can help me :)
the big condensator 1 227 330 003 is shorted, does someone know what new element I could build in in stead of this?
bosch says me that they don´t have it anymore.
thank you very much!
regards
chris
Joe Bob 03-15-2012 09:47 AM
Lot of those parts are NLA, try contacting Loren or Ingo. Early S Man passed away a few years back.
RWebb 03-15-2012 01:45 PM
It's good to see that Warren lives on in these forums.
Maybe someone who knows his family would like to contact and tell them as a sort of honor.
jmchrist 03-15-2012 02:22 PM
the big condensator may easily be replaced with a metalized polypropylene condensator of the MKP family.
A MKP condensator of 1.5 µF 630 V is the correct value to choose and can be obtained from any electronic parts retailer.
wwest 03-15-2012 07:14 PM
condensator...what is hell is that...?
jmchrist 03-16-2012 01:36 AM
"capacitor" is better, sorry.
dicklague 03-16-2012 06:52 AM
Condenser, capacitor
Big round things inside the CD box. Quite available from electronics parts suppliers, you march the voltage and capacitance rating.
All the parts inside the box are available......not from Bosch, but out there in the electronics market.
chb 03-29-2012 08:42 AM
thank you very much for the info!
I will try to get it in a electronic shop!
thanks!
regards
chb
Alfasrule 01-02-2014 03:48 PM
OK this info. is awesome! Working on Alfa Montreal Boxes same thing, Porsche has way better documentation than Alfa Romeo Guru's. Took this on as a challenge, It's FUN!! Well anyway I can figure out some of the Voltages but there are points indicated in the schematic (NUMBERS 1-8 some (A's) for voltage measurements and NO documentation on this anywhere. What gives? Can some one give a link or post on this. I'm doing this on the bench, Pulse Generator, Scope haven't broken out this stuff in years. It's a Blast. I'm going to eventually put one of these in a 4 cylinder Alfa to see what happens. Thanks for the HELP and the valuable information!
jakz 04-21-2014 03:42 PM
i really really really wish i could understand this, my CDI quitted working two days ago so i took it out to test it which i couldnt because im afraid ill make it worse
http://i267.photobucket.com/albums/i...na/photo-7.jpg
best regards
James Brown 04-21-2014 09:27 PM
i dont se bearings or zero fittings so it's all voodoo stuff, pelican offers rebuild service, contact them.
Thanks Warren!
