Test SCR
Perfect, I tested my SCR and the result is positive.
First I switched S2 and after I pushed S1, and the lamp stays on ( 3 watt + 3 watt)
WP 20141110 21 27 01 Pro - YouTube
Now, who is the guilty?
Old 11-10-2014, 01:51 PM
Does anyone know what to do?
Old 11-18-2014, 01:21 PM
Hello all
Thanks for this very useful topic!!!
Can someone help me out with an OT104 thyristor? We found out that's the part that got broken in the CDI but can't find a new one and don't know if it could be replaced by some other part that have similar function?
Any help would be very appreciated!!!
Thanks!
Wout
almost desperate to get my '74 chocolate brown rolling
Old 12-19-2014, 12:54 AM
The best replacement for this thyristor i have found in Europe is the BTW30-800 from STMicroelectronics. It has the same package (TO-48) and is specified with a Tq max of 12 µs.
The replacement by a International Rectifier 50RIA80 or similar which is not specified with a Tq max is at risk of blocking when operating at high temperature.
Old 12-19-2014, 05:47 AM
Thanks!!!!
gr
Wout
Old 12-20-2014, 06:30 AM
0396's Avatar
Excellent information. Thanks!
Old 12-20-2014, 07:58 AM
Very good thread!, subsd.
http://917burger.blogspot.com
Old 12-28-2014, 06:59 AM
Exotic Vehicles are here
1-ev.com's Avatar
There are should be US version of the BTW30-800 replacement...
Old 01-03-2015, 04:29 PM
The electrically equivalent thyristors I found with a 2Nxxxx number are not using a TO48 case.
The 2N692A Which in available worldwide is not specified with a Toff max.
It is specified with a Toff typical (not max) of 15 µs by only one US manufacturer : Central Semiconductors Corp, Hauppauge NY.
Old 01-04-2015, 09:36 AM
Hi jmchrist
Have you received my pm?
Thanks for the information!!!
gr
Wout
Old 01-05-2015, 01:51 AM
Transformer
Thanks for these useful info!
Does anybody know what transformer is used in this circuit (windings,...) and/or where I can get that part?
Old 02-13-2015, 01:16 PM
Old 02-13-2015, 01:17 PM
does anyone have more info about this bosch unit?
Old 02-02-2016, 07:29 AM
scarceller's Avatar
This may help:
TSZ Zündung CIH Manta 400 BMW 1802 GTI 914 Capri 1 W109 Golf 1 in Aachen - Aachen-Brand | eBay Kleinanzeigen
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 02-04-2016, 05:23 AM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I could be wrong but this is essentially very similar to the ignition transistor output stage found in an early Bosch DME.
The box gets triggered by the distributor and replaces the classic points. It charges the primary of the coil. Think of it as transistorized Kettering setup.
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 02-04-2016, 08:10 AM
Under the radar
Trackrash's Avatar
Can a similar test be performed on the 6 pin CDI?
Originally Posted by Early_S_Man View Post
This is the board layout/picture for the 1972 CDI unit ... it corresponds to the fig. 17 layout in the test document:
Here is the early schematic for 1969 - 1972 CDI units ... Please note that the test point labels in the test document do NOT correctly correspond to all of the labels in this version of the schematic [TP #1 and TP#2 are OK for scope tests, but to short main capacitor -- TP#4 & TP#4a are used ] ... based on an estimated 1974/75 revision:
Here is an annotated picture/layout for an early 1972 CDI unit corresponding to fig. 16 in the test document.
Here is the revised parts list showing R4 and 33 Ohm 5 Watt version of R3:
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-22-2016, 08:23 PM
You can duplicate the test and use a square wave generator for the distributor I have done it on the bench many times.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 11-22-2016, 08:37 PM
Under the radar
Trackrash's Avatar
Can I manually turn the distributor, since it is off the car?
I have a rebuilt SC motor, with unknown history, which will go in to my '71. I hope to verify the SC's CDI operation before I build a custom harness.
Thanks.
Gordon
Old 11-22-2016, 09:09 PM
ischmitz's Avatar
You can trigger the 6-pin by hand with the distributor or even with an AA battery but ideally you run the box over night at high RPM to ensure it'll not shut down when it gets hot. When I test boxes some fail only after 6h - 8h and you'd never catch that with a quick test. Alternatively you'd have to put the box into an oven heated to ~150 degF to simulate engine bay conditions.
That's why some sort of automated trigger (e.g. signal generator or your drill connected to the distributor) is preferred.
Old 11-22-2016, 10:42 PM
ischmitz's Avatar
See here for a simple triggering device for 3-pin and 6-pin boxes 6 pin CDI problem under temp.
Old 11-23-2016, 07:14 AM
Tags
cdi
