LinkBack | Thread Tools |
Under the radar
Good info.
One more quick question. On the three pin CDIs the coil has a pigtail ground to the fan housing. This is not used with the 6 pin box. Would there be any advantage for using a ground to the fan housing with the 6 pin box? Thanks,
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 11-23-2016 at 09:31 AM.. |
I doubt it. The coil needs to get GND the same as in a 3-pin since the schemtic and topology is identical to the 3-pin. However, in the SC it's through the harness and that should be sufficient.
Cheers, Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
Ian_Down_under
Question for those reading this Forum - I am in the process of repairing my Bosch 6-pin CDI (1982 Porsche 911 SC Targa) and have noted the changes suggested to date in this Forum due to obsolete / no longer manufactured components.
It appears to me that total rebuild to the original Bosch design (albeit slightly modified) would be more time/cost effective. (. I was wondering if anyone has manufactured the original Bosch CDI printed circuit board on fiberglass (FR-4 glass epoxy). If so, how do I acquire several on these boards? |
Quite a few thyristors are mentioned as replacements for the original OT-104 with a TO-48 housing for the 3-pin CDI.
In post #84 the BTW30-800 is mentioned. And in this other thread, InternationalRectifier 16RIA80 or 25RIA80, Siemens CS23-8, or the -10, -12, or -16 versions are pointed out: BOSCH CDI discrete components troubleshooting Some say these components will work, others say the won´t. I am not sure if any of them will work. My Bosch repair shop tells me a new thyristor is all they need to make my original 3-pin CDI box work again. But they can´t get a replacement part anywhere. So which one should I go for? Bosch Classic seems to be unable to help. Any help would be appreciated.
Thomas __________________ 1973 911S Targa 2.4 Last edited by ThomasTe; 10-04-2022 at 06:17 AM.. |
Contact Bob Ashlock at AshlockTech. He rebuilt my 1970 CDI 3-pin and upgraded it to modern internals. Very quick turn around, and now a reliable unit.
https://ashlocktech.com/bosch-cdi
1970 911T "Albert" 1986 944 Sold 1980 Euro 924 Sold 1967 911 Sold but Greatly Missed!! |
Do a Google search, as there are numerous sources for Bosch CDI repairs starting at $225 with a 5 year warranty.
Dave |
In my experience most SCR first appear to work but then quickly show issues when the box is at operating temperatures. The comutation fails and the SCR doesn’t turn off properly.
Sourcing an appropriate type isn’t trivial to say the least. |
Here is the info, https://ashlocktech.com/ashlocktech-cdi
From the link - "The SINGLE-PLUG unit is a direct form/fit/function replacement for your old 3 or 6-pin Bosch unit. Modern, reliable electronics is installed in your old Bosch donor housing to maintain a desirable 'stock' appearance. An added convenience is that a 3-pin unit can be converted to 6-pin or vice-versa if desired." "AshlockTECH High Performance CDI UNIT $500 Customer sends their own core unit to be cosmetically restored and retrofitted with all new modern high performance electronics. (Add $150 for outright purchase - no core)" When that modified CDI fails, it becomes a bad non-repairable core, i.e. junk like this one; ![]() Beware of what you buy and put in your 911!
Dave |
Chime
pca 30 year member,1977 porsche turbo body targa 56 vw ragtop oval 01 harley sportster 18 Chevy Colorado diesel BIG RED Firetruck and assorted v-dub ,porsche parts hoarder..LoL |
History of Bosch CDI ... toubleshooting info, parts list changes, and schematics ...
Actually it’s the older design Bosch that is less efficient with dated components that also waste more of the incoming energy as heat. Old Bosch CDI units are also prone to sudden failure and one of the culprits that will leave a driver stranded. In addition, there are at least two other modernized CDI designs trying to address the same original design flaws of the original Bosch unit - P:::sK:::::k and Classic Retrofit. Bob Ashlock is a top shelf gentleman that puts out a great product at a very fair price. So far he has done two CDI boxes for me (and does work for our host - search CDI rebuild) and they both work flawlessly. https://www.pelicanparts.com/More_Info/ATCDIREPAIR.htm?pn=AT-CDIREPAIR Bob is one of the good guys.
Tonger Last edited by Tonger; 10-06-2022 at 07:10 AM.. |
You do know how to measure potential spark energy and losses, right? Please define which components are dated. You do know the difference between an active & passive electronic component? Really? Let's not continue to provide hyperbole! Provide some data. Post a picture of the inside of your "modern" CDI, with some oscilloscope images of the spark output. Quote:
The link you provided basically is just an analysis of the how the Bosch CDIs function and doesn't directly relate to the specificity of the "modern" CDI. https://forums.pelicanparts.com/porsche-911-technical-forum/938050-bosch-cdi-voltage-regulation.html There's a Bosch CDI rebuilder, a previous Pelican supplier, that's been rebuilding Bosch CDI's and other Porsche electronics for over 40 years with a five warranty to Porsche independents and dealers, and a zero failure rate.
Dave Last edited by mysocal911; 10-06-2022 at 03:52 PM.. |
Hi Dave/Loren - I see I've stumbled upon your pseudonym account and you have a business rebuilding stock electronics. You've already discussed this at length with folks like Jonny and Winterburn that know much more than I.
https://forums.pelicanparts.com/porsche-911-technical-forum/938050-bosch-cdi-voltage-regulation.html Quote:
Hmmm - I wonder who this rebuilder could possibly be - "Dave"?
Tonger Last edited by Tonger; 10-06-2022 at 07:08 AM.. |
Popcorn time:
Act one: Loren on the merits of chip Tuning Act two: Correlation of basic intelligence and ability to troubleshoot a 3.2 no-start Act 3: Bosch CDI vs. aftermarket solutions Epiloge: don’t take your business anywhere - they’re all scammers !!! |
Appendix A: Inductive is better than CDI except for Standard Bosch CDI which is better than sex.
www.classicretrofit.com |
Pelican Parts direct competition, i.e. rebuilt CDIs, Motronic DME ECMs, & performance chips, allowed to advertize?
What prevents other competitors from doing the same?
Dave Last edited by mysocal911; 10-06-2022 at 09:19 PM.. |
Nothing stopping you but I guess it’s difficult to advertise your skills if you’re pretending to be someone else! Must be annoying.
![]() It's a very simple setup with ignition map programming using an inexpensive coil, e.g. Bosch blue coil. The IDI mode, used on all present day internal combustion engines, provides longer spark burn times than CDI systems, e.g. more complete combustion. Furthermore, IDI systems are inherently more reliable than a CDI system, no need for a capacitor.
Dave Last edited by mysocal911; 10-07-2022 at 02:41 PM.. |
| Tags |
| cdi |
