Yes some more braking questions long / Wilwood vs Boxster
Hi,
I currently have Carrera brakes in the front, and well I what more stopping power.
I was looking a WilWood Calipers
and
Boxster Calipers
Both are 4 piston and light.Both need to have some type of bracket to mount to my 3.5 holes.
The Wilwood are priced very nice so What do I do?
A. Has anyone used the Wilwood's what did it take to make it work? What do you think?
B Have you used the Boxster brake on the front, what did it take to make it work,what do you think?
C. What are "Hats"
D. Can I keep the 16' rims?
http://www.hrpworld.com/index.cfm?form_cat_id=533,260,49,363&action=category
Derek
Car in question
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 06-14-2005, 09:45 PM
Sumotang's Avatar
There are lots of threads on the boxster brakes at the front. From reading the threads, the boxster calipers will fit 15" wheels. Most people if opting for the boxster brakes at the front upgrade the rears to Carerra brakes to keep the bias correct.
Damo
83SC 'Guards Red' - Sold
1994 993 C4
Old 06-14-2005, 10:03 PM
I ahve read over some of the thread, but tnobody goes in to detail what needs to =be done.
2011 M3 4Door
Old 06-14-2005, 10:05 PM
jyl jyl is online now
jyl's Avatar
From my experience, there isn't much to it. Get the Boxster front calipers (not Boxster "S"; call Porsche dismantlers) and the adapters (www.tremotorsports.com and others), switch the cross-over tube and the bleed screws (so that the smaller piston is the leading one), use pads that won't squeal, bolt the calipers on, and bend a new hard line. That's it.
Here is a thread. Pics Of My Brake Rebuild (w/ Boxster Fronts)
What do I think? Well, I haven't done any track or AX since the brake work, so all I know is how the brakes work on the street, and they work great, but to be honest they worked well before too, so basically I now have brakes that are somewhat more powerful, need somewhat more care to avoid locking up, and look a whole lot nicer.
Old 06-14-2005, 10:46 PM
I also found a brand caller Boxer, that will change over as well
2011 M3 4Door
Old 06-15-2005, 01:46 AM
Work in Progress
Rich76_911s's Avatar
Just incase you have not seen Bill V's page on brake mods here it is:
http://home.nycap.rr.com/wmv/generalbrmd.htm
there is a small fortune of information and links from that page. If you happen to have some spare time at work today it is a good way to blow an hour.
"The reason most people give up is because they look at how far they have to go, not how far they have come." -Bruce Anderson via FB
-Marine Blue '87 930
Old 06-15-2005, 04:02 AM
len911's Avatar
Have you looked at this? http://www.boxermotorsports.com/who.asp
I have their front and rear upgrade. Just completed my project so I can't give you any feedback on performance. But it was pretty much bolt in. Uses Wilwood rotors up front (11.25x1.25) and Outlaw calipers. Billet, used in Nascar Truck series. Check out http://www.outlawdiscbrakes.com/ I believe is their 4000 series.
Rotors are cheap about $45 ea., pads are common type used by other types of racing cars. They make them for both 3 and 3.5" strut spacing. Saved me some $$. They use a smaller caliper in back with Carrera rotors.
Lou
'76 911 "Moneypenny" daily driver
'74 911 "JLo" IROC DE Car
'03 CRV, '02 Jeep Grand Cherokee
'03 Holiday Rambler Admiral SE, 30ft, 8.1l, 340HP, 455Ft#
http://www.nicotra4.hpshare.net/BasketCaseMotorsports/
Old 06-15-2005, 04:45 AM
Can you just use the WIlwoods with out changing the rotors?
2011 M3 4Door
Old 06-15-2005, 06:36 AM
RallyJon's Avatar
You can specify rotor thickness for Wilwood calipers. If you want Wilwoods, you should primarily consider the Dynapro. Unlike the older Dynalite and Superlite calipers that gave Wilwood a bad name, the Dynapro is a forged, modern design with dust boots. It also can be ordered in a width to fit 20mm SC rotors and piston size to match the stock bias and work with the stock MC. Pad height looks pretty good too.
Go on--be a guinea pig and try them!
Edit: as near as I can figure, you want the 35.1mm pistons (for a piston area of 1935mm˛ vs 1809mm˛ stock). Part number 120-7376: http://www.wilwood.com/PDF/fl119.pdf
993 · 911 · STI · S4 · rally car
Old 06-15-2005, 06:48 AM
MBruns for President
JeremyD's Avatar
www.probraking.net he makes a kit to use 993 brakes with custom hats and wilwood rotors. I have 3 DE's on mine - they are outstanding
Old 06-15-2005, 07:45 AM
}{arlequin's Avatar
don't remember who, but someone on the board had wilwoods on their car
edit: Pics Of My Brake Rebuild (w/ Boxster Fronts) (boxster)
Interesting new Porsche/Wilwood brake option (wilwoods)
dave
1973,5
Old 06-15-2005, 07:54 AM
Bill Verburg's Avatar
I currently had the SC brakes in the front, and well I what more stopping power
For more stopping power i.e. shorter stops you need to improve the tire situation on you car. 911s are stoping distance limited by tires not brake torque
Bill Verburg
Old 06-15-2005, 09:36 AM
All true
Bill Verburg
Old 06-15-2005, 09:37 AM
Also all true
Bill Verburg
Old 06-15-2005, 09:38 AM
Lou
At least Lou has addressed most of the 911 brake issues
Bill Verburg
Old 06-15-2005, 09:40 AM
Also true, but unless you use bigger rotors than stock, the primary 911 brake issue has not been addressed.
Bill Verburg
Old 06-15-2005, 09:42 AM
Also true
Bill Verburg
Old 06-15-2005, 09:43 AM
C. What are "Hats"
2 main styles of rotor are 1 piece or 2 piece
the 2 piece use a hat bolted to the hub and rotor
These are 1 piece Zimmermans for an SC
this is a 2 piece 993tt rotor w/ a flat hat for use on a 911 front end
this is the back side of a 2 piece Colman 930 size rotor bolted to a flat 911 type hat
Bill Verburg
Old 06-15-2005, 09:59 AM
}{arlequin's Avatar
Bill, what do you think of these mounting "hats"? (They call it Dynamic Mount Plate) Looks like they wouldn't add any undesirable offset....
http://www.wilwood.com/Products/003-Hats/001-DMP/index.asp
dave
1973,5
Old 06-15-2005, 10:33 AM
randywebb's Avatar
In case it isn't clear the hat is the smaller dia. part that looks like a ... well, a "hat" if you think of the wide brim as being the rotor itself. It's the part that has depth to it in the pics above.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 06-15-2005, 10:56 AM
