Automotive Monomaniac
Emission's Avatar
High Speed stability issues - diagnostics?
I've had my Porsche for three years now. It has always been rock solid at speed (up to nearly 160 mph)... until recently.
As of the past month or two, I've noticed at speeds over 80 mph, the car is a bit skittish, darty maybe. When I apply the brakes, the car even seems to get a bit more unsettled.
Yesterday, I had it at about 150 mph (in the California desert) and it was downright scary - really had me concerned as it wasn't stable at all. I lifted off the gas and coasted until well below 100 before I applied the brakes.
The car has new shocks on all four corners, new front bearings (they are tight, I just checked), good front tires, brand-new rear tires, stock aerodynamics front and rear...
I don't think it is aerodynamics. I don't think it is street tires as it was acting a bit funny on the R-compound rubber when I had it at the track a few weeks ago. The alignment was just done about two months ago - and it tracks perfectly straight - but it is still suspect.
What do you all think?
Alignment?
Bushings (I think they are original)?
Other?
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 06-20-2005, 09:33 AM
Registered abUser
TerryH's Avatar
What about aerodynamics? At those speeds, anything passing under the car is going to create lift.
.... and holy smokes! Don't get caught driving those speeds. You'd probably lose the car and your freedom.
'81 911SC Coupe SOLD
Old 06-20-2005, 09:39 AM
Emission's Avatar
I rule out aerodynamics as the car has the stock front chin and rear spoilers both intact and unmodified. The car is also at Euro ride height. It doesn't feel like it is lifting - just unstable.
Old 06-20-2005, 09:50 AM
Gon fix it with me hammer
svandamme's Avatar
sounds like to much in the back
not enough pressure in the front
high speeds give you front lift
when you apply brakes, the weight tranfers brutally and gives the car the shakes...
with your new shocks and alignment , possibly it has less rake now
front a bit higher, the back a bit lower... just one idea...
Stijn Vandamme
BIMDIESELBMW116D2019
Old 06-20-2005, 09:51 AM
Emission's Avatar
"New" shocks means 5,000 miles on them - two years ago at the rate I drive. The car sits level.
I am thinking the car needs new suspension bushings. Does this make sense? Would old bushings "give" under stress (at higher speeds/loads) and braking would compress them even more - both distorting the suspension settings causing my instability?
Old 06-20-2005, 10:04 AM
Formerly bb80sc
Vipergrün's Avatar
Hows your alignment? Toe settings?
Cheers
-Brad
2015 Cayman GTS
2015 4Runner Limited
Old 06-20-2005, 10:45 AM
Emission's Avatar
My tires are different too... would that make a difference?
Front - Yokohama AVS Intermediates
Rear - Yokohama AVS Sports
I don't seem to remember if the stability issue existed before the tire change...
Old 06-20-2005, 11:12 AM
Formerly bb80sc
Vipergrün's Avatar
I'd say yes due to differences in tread pattern, possible differences in sidewalls, etc...
Cheers
-Brad
2015 Cayman GTS
Old 06-20-2005, 11:17 AM
Emission's Avatar
Crap.
My wrench thinks the tires are also the issue, followed by alignment settings. Bushings are probably not the issue.
I am not in the mood to dump another $320 on front tires when the existing tires are still good. Really sucks.
Old 06-20-2005, 11:22 AM
Formerly bb80sc
Vipergrün's Avatar
Now's your change so burn some rubber and wear those puppies out You could probably sell them in the classifieds...
Cheers
-Brad
2015 Cayman GTS
Old 06-20-2005, 11:39 AM
Emission's Avatar
Too bad they are the fronts...
Old 06-20-2005, 11:51 AM
VZ935's Avatar
Send a message via AIM to VZ935
Your problem is your toe setting.
A bunch of old race cars
Old 06-20-2005, 03:09 PM
Stranger on the Internet
patkeefe's Avatar
You have original suspension bushings, and your wrench thinks that's not the cause?
Patrick E. Keefe
78 SC
Old 06-20-2005, 03:17 PM
Emission's Avatar
Well, let me clarify:
My "wrench" - the guy who actually physically will work on my car - hasn't been asked.
My "wrench" (who I referred to) - the mechanic who I have known for years but lives too far to touch my car - says it's not the bushings. He has a 951 (944 turbo) with the same issue, different tires on each end causing instability.
I'd much rather drop $150 in alignment and parts for bushings than spend $350 on new front tires.
There is a thread somewhere about good alignment shops in the area. I need to search and find it.
Old 06-20-2005, 04:17 PM
Formerly bb80sc
Vipergrün's Avatar
I'd try Tyson at TRE first, if they do full alignments, then try
Johnson Alignment in Torrance, talk to Steve Alarcon.
Cheers
-Brad
2015 Cayman GTS
Old 06-20-2005, 05:46 PM
PRO Motorsports
Tyson Schmidt's Avatar
If your rear tires are brand new, and the fronts aren't, then the car will be squirrelly until the rears are scrubbed-in and heat cycled.
Basically, the rear tires are brand new squishy sidewalls, with tall tread blocks on them, and the squirm around more than the fronts.
This isn't such an issue if you buy tires with the N rating on the sidewall. These denote tires that Porsche has spec'd as being compatible with their cars. They have a stiffer sidewall.
'69 911E coupe' RSR clone-in-progress (retired 911-Spec racer)
'72 911T Targa MFI 2.4E spec(Formerly "Scruffy")
2004 GT3
Old 06-20-2005, 05:54 PM
patkeefe's Avatar
OK. This problem is obviously not the aerodynamics, as they are the same a s always. Does it on two different sets of tires. You have relatively new shocks and alignment...do the tires wear differently L -R, are they scalloped or tread worn funny?
I would at the very least look at the bushings, ball joints and tie rods, and check the rack. Are your tires balanced (maybe you lost some weights)?
My limited knowledge of this is that once you introduce any sort of bind into the suspension, it gets squirrely. Are your alignment and CB numbers repeatable? Are you getting vibration back into the steering column, or just a bit of loss of control?
Patrick E. Keefe
78 SC
Old 06-20-2005, 06:03 PM
al lkosmal's Avatar
I would check alignment first.
RGruppe #669
http://www.x-faktory.com/
Old 06-20-2005, 06:14 PM
patkeefe's Avatar
Tyson:
Where would one find this "N" rating? Is it marked on the sidewall somewhere?
Pat
Patrick E. Keefe
78 SC
Old 06-20-2005, 06:25 PM
Emission's Avatar
All great advice.
1. I like Tyson's comment about the brand-new rear tires. They have about 80 miles on them, and they had not been heat cycled.
2. Put the car in the air and check all visible bushings/suspension.
3. Have the alignment checked/re-done
4. If all else fails, buy new front tires.
Old 06-20-2005, 06:52 PM
