Should I build it? AC questions
As the summer heat starts to set in and the lack drive to DRIVE the Non A/C early Porsche , the wheels start spinning(in my head , well a few anyway).
I know Alot of us have removed our A/C systems from our cars to save weight and maybe get rid of something that does not work very well all the time anyway.
SO , it still pretty hot out what to do what to do?
Do you put a Vintage air system in? No
Not drive the car. Thats no fun
So I think I have a solution,
And I like to see if there is any interest.
What if the is a A/C unit that is sell contained,
Does not need to run off the engine , just plug it in to lighter
And you can remove it when you ge to the track
Weighs about 45# and has and 250 cfm
ALL this and it is under $300
So you have it run when you what to drive around and to the track, get to the track, and pull it out , and unplug it
IT sits in the trunk and need very little to hook up.
Do ya'll think that people (Porsche People) Will like something like this?
I am think about building one, and if there is some interest maybe a few more.
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 06-21-2005, 09:27 PM
scottb's Avatar
Derek: What are you going to do to exhaust the hot air?
1984 Targa
Old 06-21-2005, 09:47 PM
ruf-porsche's Avatar
Easy, open the windows.
Old 06-22-2005, 04:14 AM
I would take a look at it definitely. If it is unobtrusive, maybe housed in the trunk and could be powered from the fuse panel or battery instead of the lighter, that would be even better. I need one about 2, maybe 3 months a year, but that is it. Sounds like a good idea. Send me what you have.
Sean
'77 911S Cab Conversion
Old 06-22-2005, 04:20 AM
evill's Avatar
I think it would be difficult to run an a/c unit from just the battery.
What would the amperage requirements be?
Ed
BTW- when I was a kid, my friends dad had a JC Whitney a/c unit similar to this. It was tub you filled with ice, with a12 volt fan that blew the air over the ice to cool it. Maybe you could do something like this with an Igloo cooler and a fan?
Basically, I'm One Giant Train Wreck.
http://community.webshots.com/user/evill914
Old 06-22-2005, 04:41 AM
Designer King
Paulporsche's Avatar
Deoxford,
If you build it we will come.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-22-2005, 05:09 AM
The concept is not new, in fact it's been already done, and with a PORSCHE no less.
Just a small window air connected to an inverter.
Old 06-22-2005, 05:31 AM
Ed,
I was thinking about the ones with the Ice and they are cheap about $122
Well there is is , in a 914 THat is the basic idea.
2011 M3 4Door
Old 06-22-2005, 07:30 AM
