pop valve popping out! help!!!
Hey guys. I'm pretty new here and I got an issue with my 911sc.
I just replaced the fuel pump and once in awhile I try to start it and it starts up but makes a sound like it's gonna stall or choke. Then it makes a small pop sound. When I open the airbox, my pop off valve came off. You can see some smoke coming out of the hole. Not alot though. It does this once in ahile. The mechanis said I need to adjust my fuel. What do you guys think? Thanks!!
Old 06-22-2005, 07:36 PM
ras911's Avatar
Not sure , but seems you need to check the mixture and definitely you need to secure that pop off valve other wise it will keep blowing out . There is a epoxy (either w&b or J&B Weld or something along that line) that is supposed to work well on plastic. Available in your local hardware.
Bob
1983 911SC Coupe Platinum Metallic
2020 Macan Dolomite Silver
PCA Member
Old 06-22-2005, 08:14 PM
Where is that wrench?
EdT82SC's Avatar
My pop off valve popped out. I used JB Weld to put it back in, and I haven't had a problem since. Have your mechanic adjust the mixture. It should only take him a fe minutes.
Ed T.
1982 911SC
Porsche Wallpaper
Old 06-22-2005, 09:16 PM
Thanks alot you guys! I'll try that.
Old 06-22-2005, 09:54 PM
Bill Douglas's Avatar
And rough up the surface you are going to epoxy with some sandpaper. Expoy has trouble getting a grip on very smooth surfaces.
Old 06-22-2005, 10:17 PM
dandrews64's Avatar
Heed Bill's advice. I had the same problem and scuffed and cleansed with brakleen the surface before re-epoxing. Been 12 months now. (fingers crossed for anti-jinx!!)
Doug Andrews
1982 911SC Targa
2008 Silverado Duramax 3/4 ton
2004 Armada
1999 Honda XR400
Old 06-22-2005, 11:00 PM
By any chance do you guys know how I can adjust the mixture myself? Thanks!
Old 06-23-2005, 12:32 PM
Depends on the year and if it's been done before. For earlier cars the adjustment is with a long 3mm alen wrench that goes into the top of the air sensor box between the fuel distributer and the big rubber boot.
Clockwise = richen
Counter clockwise = leaner
This is easy to screw up if you go too far.
Supposed to be done with a gastester. Look up Gunson Gastester for a cheap model.
A few more details with later SC's with lambda control.
Also I have herd, but not seen that the US models are supposed to have a tamper proof plug that needs to be drilled out. The procedures in the manual say to remove the unit which is a lot of work. There must be someone who has an easier way. Most likely it's already gone.
I'm sure someone will fill in more details if you supply more info on your car.
Luck!
Bill Miller
81 Targa Guards Red
3.6, M&K 1 out, S4 brakes
83 ROW CAB Rubinrot Metallic (RIP)
Old 06-23-2005, 12:51 PM
Thanks a million! I'll try that out. My mechanic told me to richen it. Keep you guys updated.
Old 06-23-2005, 01:00 PM
Just keep track of how many turns. It is nice to be able to go back to square one if necessary.
Old 06-23-2005, 01:40 PM
Designer King
Paulporsche's Avatar
Remember, a little goes a long way. According to previous posts, one complete revolution seems to be somewhere between 8 and 12%! If you are doing this without a gastester, go in 1/32 or 1/16 turn increments.
If the idle starts to fluctuate or if the engine wants to stall when you come off the throttle when coming to a stop, your mixture is too rich. You should back it off 1/32 or 1/16 turn or so from there. If you do this on a hot, humid day, then you should be good. If it gets hotter and more humid later, you may have to lean it a little again.
I don't know where Oaktown is (Oakland?), but if your temps drop in the fall, you may have to richen it back.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 06-23-2005, 02:44 PM
Thanks. I'll give it a try later after work. Yeah it's oakland. It sounds nicer, don't it? When I say Oakland people tend to say bad stuff.
Old 06-23-2005, 03:54 PM
