abit off center
cgarr's Avatar
Anyone using Tec-3 in place of Motronic?
Just thinking out loud here,, I dont want to use the 3.2 Motronic when I upgrade my 3.2 this winter to a 3.4, J&E's 10.5/1 twin plug etc,etc,, Looking at the cost of just the twin plug setup and not being able to have Steve W sitting next to me burning chips, it does not look like a bad idea if its really a good system, Anyone using the new Tec3r? Looks to me like you scrap just about everything but the injectors and the intake manifold?
Craig
Old 06-23-2005, 10:44 AM
abit off center
cgarr's Avatar
Well? I guess I will give it a try, Going to scrap the complete intake and go with the ITB's and twin plug setup, kinda pricy but if I dont spend it the wife will!!
Craig
______________________
Craig
G2Performance
Old 07-08-2005, 06:36 PM
Jeff Alton's Avatar
What ITB's are you going with??
Jeff
www.turn3autosport.com
Old 07-08-2005, 06:40 PM
AvonGil's Avatar
I would if I where you! Programable EFI is much more modern than the motronic in the Carrera. They are easy to install and very reliable. For a twin plug setup, id say its a no brainer! If going to individual throttle bodies you will be using a speed density set up - Manifold Air temp + Manifold air pressure + Throttle position. If you are sticking to the carrera intake, you will be using Mass Air Flow (GM Hot wire sensor) + Throttle position. Either way, out goes that restrictive motronic flapper box!
BTW - I converted a CIS car to a fuel only computer(haltech f9a), it was fairly straight forward and made the car so much more drivable. Im a big fan of Programable EFI, I think many people are scared of it, but its pretty simple and actualy quite crude!
95' Mercedes E300 Diesel (Azure+Sodalith Blue)
88' Porsche 911 Targa (FOR SALE) (Guards Red)
Old 07-08-2005, 06:57 PM
Navin Johnson
TimT's Avatar
Yes
Tec works as do others. Haltech, Motec, Dastek, EFI systems, SDS,Link Autronic...'
most just need a few inputs from the existing sensors on an engine of yours
'69 911 GT-5
'75 914 GT-3
and others
Old 07-08-2005, 07:07 PM
siverson's Avatar
Send a message via AIM to siverson
And I still have my Tec3 system for sale...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=7980639469
-Steve
Old 07-08-2005, 07:28 PM
Rob Channell's Avatar
Let us know how it works out. I've always wanted to try one of these.
Rob Channell
One Way Motorsports
1979 911SC mostly stock
1972 911T Targa now with a good 2.7
1990 Miata (cheap 'n easy)
1993 C1500 Silverado (parts getter)
Old 07-08-2005, 08:16 PM
Jeff Alton's Avatar
I am currently trying to piece together a set up using Jenveys ITB's and probably a Haltech (shameless plug for TimT) It will either be on a 3.6 or a 3.4 twin plug that I am putting together. Will keep people posted as this gets put together. Just be patient.
Cheers, Jeff
Old 07-08-2005, 08:54 PM
Porsche Doc's Avatar
I vote TEC3.
Its what we use it when do an engine managment system.
We have been using then for years.
www.clewett.com
Here it some pics of cars we have used it on,one we are doing now.
Thanks!
Don Ramsay E Mail: aircooledclassicsporsche@gmail.com
The father of 964 Backdating!
www.aircooledclassics.co
www.facebook.com/AirCooledClassicsPorsche/ www.instagram.com/aircooledclassicsporsche/
abit off center
cgarr's Avatar
I would be using the kit from Clewett which uses the TWM tb's and they would offer the support I really need. I have looked a the cost of twin plug, extrude hone, bore the TB custom chip etc, all these costs really add up quick, with the kit it looks to crap it all, if it really works?
Craig
Craig
G2Performance
Old 07-09-2005, 04:03 AM
Mike Bonkalski's Avatar
How about the Motomotions TWM/Megasquirt kit for under $3K?
1971 Targa RS - Sold
1964 BMW 1800Ti
1969 BMW 2002
Old 07-09-2005, 05:44 AM
abit off center
cgarr's Avatar
Does the megasquirt control the ignition for twin plug too? If so tell me more!! Like Ross said "im all ears" and just in the planning stage right now.
Craig
Old 07-10-2005, 12:08 PM
Jeff Alton's Avatar
Mike, are you up and running now with that motor?
Jeff
Old 07-10-2005, 02:10 PM
Brother's Avatar
If you get teh EDIS controls for ignition with that kit, I'd be down.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 07-10-2005, 02:36 PM
Yes, you can twin-plug quite easily with the EDIS/Megasquirt system. Just run another coil pack in parallel.
I should be up and running soon. Souk and I were doing a final once over on the fuel system plumbing and found that I installed the wrong fitting in the end of one of the fuel rails. The way it is set up, the fitting won't make a good seal and it may leak. So I ordered a new fitting. Once that is in place, I will start it up.
Brother - You would be right at $3K with EDIS. If you want a full list of what the kit includes, send me a PM.
1964 BMW 1800Ti
1969 BMW 2002
Old 07-10-2005, 02:50 PM
Nitrometano's Avatar
Try Sakura EFI. The complete set for $1,375. www.sakuramotorsports.com.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 07-10-2005, 03:00 PM
Jeff Alton's Avatar
Isn't that for fuel only?
Jeff
Old 07-10-2005, 05:21 PM
89turbocabmike's Avatar
Sakura is fuel only.
Old 07-10-2005, 10:59 PM
AntiCHP's Avatar
Send a message via AIM to AntiCHP
Mike,
That sounds like exactly what I'll need for my 3.6 project since I have no induction and no ignition lined up as the motor (slowly) begins to come together.
I sent you a PM to solicite more details.
"...and not just because today is my birthday, Your Honor, -but because of how the vehicle code defines a speed trap- I ask that you dismiss this case."
Old 07-10-2005, 11:25 PM
