Banned
What to use- clean up alloy wheels
I just had delivered a set of 996 rims for use as track wheels. Not terribly fussed about their appearence, but they need a good cleaning up. What can I use on a natural alloy rim to remove gunk, adhesive residue, general crap from brakes and grease?
TIA
Stuart
Old 06-22-2005, 05:38 PM
19 years and 17k posts...
azasadny's Avatar
I use Simple Green and alot of rinsing with a garden hose...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 06-22-2005, 06:47 PM
Location: member Central PA Region PCA , Home of the Hershey Swap
Simple Green is not a good choice because it is a strong alkyli. It can easily pit or streak your wheels permanently. I would use P21S orange then use an adhesive remover.
regards,
Frequent Pelican Customer
1984 Carrera 3.2 (S. Wong Chip, B&B dual exhaust, Lightened OEM Flywheel, Centerforce Clutch, OEM 930 Rear and Front Sway Away 930 T-bars and sway bars w/OEM susp. bushings,, Turbo Tie Rods, bump steer kit, Adj. Rear Spring Plates, OEM Short Shift, H4s and "City Lights", slotted rotors, 944 Wheels, 225/50/16 and 245/40/16 Dunlop "sneakers," and more
2002 996 TT X50 (H&R Springs)
2002 WRX in WRX Blue
Proud Rennlist Charter Member
Support and Join Rennlist.com
An Expert on absolutely nothin' more than my own opinions!
Old 06-22-2005, 06:55 PM
Banned
fastpat's Avatar
I use P21S on my wheels when the brake dust accumulation, particularly on the inner surface of a wheel, has caked on over months, or even years on used wheels.
For ordinary care of a Fuchs wheel, I'd suggest low alkaline soap, even baby shampoo, in plain water then hose it off and apply a high quality wax or vaseline (as Porsche recommends).
Old 06-22-2005, 09:10 PM
Nitrometano's Avatar
I use Dawn to clean my polished Fuchs and tires.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 06-22-2005, 09:37 PM
Clay/detail spray, then any quality wheel cleaner. ie autoglym, mothers, etc.
Simon
85' Carrera 3.2
02' Mazda MX5
Old 06-23-2005, 02:50 AM
ruf-porsche's Avatar
What a Lucky guy, having a girl to clean your wheels, does she have a sister?
LOL
Old 06-23-2005, 02:55 AM
She also clean the engine and the under car!!! Wow great lady!!!
1972 911T
Old 06-23-2005, 07:48 PM
