Rennch on YouTube
rennch's Avatar
Send a message via AIM to rennch Send a message via Yahoo to rennch
2.4 motor out of 2.0 core?
I've got a stock 69T motor that I was thinking of selling with my 72T rusto-project. Is it possible to rebuild the 2.0 motor to 2.4 specs so someone would have the most "OEM" like motor in the 72? Aside from that, the 72 is stock.
Thanks,
mto
Michael O'Neal -
69 RSR Clone(ish) - The build: http://bit.ly/69porschersr
69 911S Blasphemy Build on YouTube
Rennch Youtube Channel: http://rennch.com/Youtube Instagram: https://www.instagram.com/_rennch_/
Old 06-27-2005, 09:05 AM
304065's Avatar
MTO,
Sure, it's possible. You would need
70.4mm crank from 2.4 or 2.7 motor
84mm cylinders from 2.0 or 2.4 motor
2.4 pistons from 2.4 motor or JE
Case squirters and other modifications to '69 mag case to bring it up to '74 specs
. . . in short, you'd end up buying all the parts to a 2.4 to modify the '69T, which numbers would only match YOUR car. . . why not put the engine aside for a rainy day?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 06-27-2005, 10:08 AM
Rennch on YouTube
rennch's Avatar
Well...that's the question. I'm trying to sell the engine WITH the car, and for someone who wanted an OEM 2.4 motor in the 72, I wanted to make sure it was possible. So...I have a 72T shell, and a 69 2.0 Motor. Just wanted to make sure it was possible....
Michael O'Neal -
Old 06-27-2005, 10:12 AM
