How many alternator pulley shims on a G50?
I don't know how many threads I've read that cautions about using a total (inside & outside) of EXACTLY 6 altenator pulley shims. On my '88, when I removed the pulley, I discovered 7 shims, so I removed one, and now I'm second guessing myself. Can someone confirm that 6 is indeed the correct number of shims for an '88. Thanks in advance!
Virginia Rocks!
Keith
When I changed my belt, I found that there were only 4 on mine! I had to order more, but the car was fine up until that point. I don't think that really answered your question, but you can have more or less than the 6 and still run the car...
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
UFLYICU
My 88 has six (3 in, 3 out) and never a slip.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
Thanks guys! Steve, that's why I was second guessing myself, as I had read of many instances where folks discovered they had less than 6 shims (which over time could cause undue wear), but I'd never read of anyone having more than 6. Thanks Zoanas...that makes me feel a whole lot better about my decision to remove one when I reinstalled everything.
UFLYICU
Yeah, the critical number is how many you have INSIDE the pulley, as that determines the grip on the belt. How many "spares" you have outside the pulley, under the nut is irrelevant.
Turgid Member
Had 7 on mine, too. Removed one with no ill effects.
'87 Carrera "Man who go through airport turnstile sideways going to Bangkok" |
The reason to make sure there are 6 is that if you only need 1 or 2 between pulley halves and don't install the other 4 or 5 outside the halves, the nut has the potential to bottom out on the shaft without actually putting the correct pressure on the outer pulley half. This is bad as not only will your belt not be tight enough, your pulley halves will be moving all over the place as the alternator shaft rotates. Having too many total won't be a problem until you start running out of threads for the nut or if there's not enough notched shaft for them to rest on and they start moving all over the place too. 7 shouldn't get you to that point... Of course, this is all IIRC of course!
-Todd '89 930, '97 TLC (Toyota Land Cruiser), '96 T-100pick-em-up '95 BMW R100 GSPD (gone but not forgotten), '07 BMW R1200GSA |
Southern Class & Sass
My '88 had five shims. Never presented a problem, but I added one to bring it to six.
Now if only I could find the correct width belt...
Dixie Bradenton, FL 2013 Camaro ZL1 |
Todd Doing business with leebparts? http://forums.pelicanparts.com/porsche-911-used-parts-sale-wanted/555068-attn-leebparts-please-contact-me.html |
UFLYICU
_______________________ Racer Rix Spec911 #5 prc-racing.com Last edited by ZOA NOM; 06-28-2005 at 12:00 PM.. |
Todd, it can be fixed, this happenned to me years ago. Quick weld and a little time being careful with a file and it was good as new!
Jeff
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
