TerryBPP's Avatar
Turbo guru's needed
Im collecting parts for my turbo "project" and relized I dont have a clue as to which of these is the oil feed hole and the oil return hole. Can you guys help me out?
Old 06-28-2005, 09:10 AM
Unregistered
sammyg2's Avatar
Based on what I can see in the picture and what I know from playing with turbos, the flange (top arrow in your picture) is prolly the oil drain and needs to be at the bottom, or within a few degrees from bottom. the oil feed should be 180 from the flange and is threaded for a fitting. It looks like you have a garrett? turbo, and if so the side taps are for water cooling and should be plugged in an air cooled application.
Old 06-28-2005, 09:33 AM
TerryBPP's Avatar
Its a garrett T4 Super-60 .42 intake/.48 exhaust. And thank you.
Old 06-28-2005, 09:34 AM
beepbeep's Avatar
Not that I'm a guru but that looks like watercooled turbo. Top arrow looks like oil-drain and bottom arrow is water input or output. Looks like custom turbo from some passenger car with that 90-degree elbow just behind the turbine...which car is thing going into?
Thank you for your time,
Old 06-28-2005, 09:43 AM
TerryBPP's Avatar
I'm going to put it on the 318i bmw. I just got the exhaust manifold and the FMU. Still need bigger injectors. I'm going to run it without an intercooler at first and then add one later.
So where is the return hole?
Old 06-28-2005, 09:53 AM
TerryBPP's Avatar
Here's the other side
Old 06-28-2005, 10:03 AM
beepbeep's Avatar
It doesn't matter which way you push water trough it...oil input is top one on second picture and oil-drain is top on first picture.
Old 06-28-2005, 10:11 AM
beepbeep's Avatar
P.S. Vert¡cal line going trough oil flanges shouldn't tilt more than 15 deg. from vertical axle in any direction, according to Garrett specs.
Old 06-28-2005, 10:13 AM
TerryBPP's Avatar
Thanks beeper. Do you think I should get one that doesnt have the water cooling?
Old 06-28-2005, 10:14 AM
rick conrath's Avatar
If you can run a water line to the turbo, it's a cooler running setup.
Rick
'78 930
Old 06-28-2005, 10:26 AM
Unregistered
sammyg2's Avatar
If it's going into a BMW, by all means hook up water to it.
If it was going in a 911 then you would plug the water ports.
Oil in is the smaller round hole, oil out is the larger square hole.
Old 06-28-2005, 10:50 AM
beepbeep's Avatar
Nope, keep it. Watercooling is a good thing, as long as water exists. No need for cooldown procedure.
Old 06-28-2005, 11:29 AM
