Carl83911's Avatar
What Exactly Does "corner Balance" Mean
Excuse my ignorance. Is it not enough having the wheels aligned and wheels balanced?
Carl,
Old 06-29-2005, 11:54 AM
Hey Carl,
Check this out for everything you wanted to know:
* CORNER balanced - numbers from this...and the weight
-Chris
1987 Guards Red Targa (sold)
2006 Toyota Tundra DC 4x4, the "man-e-van"
1998 CR500
Well on the fringe......
Old 06-29-2005, 11:59 AM
chrisp's Avatar
An equal corner balance means the cross corner weights match.
For a car turning right and left (like a typical road course car) the goal is a 50%/50% corner balance.
The left front and right rear total should equal the total for the right front and left rear.
You also want the front to rear balance to match from side to side as well as the total LF-LR compared to the total RF-RR
It should be measured with driver in the car.
Depending on track configuration you may want to weight jack different corners to get the car to do different things. This is similar the the heavy left side loading that Nextel Cup cars use. They want the weight to the inside so the car turns left more easily and gets better grip through left turns. They do a bunch more stuff to get them to turn better, not just corner loading.
'83 SC
Old 06-29-2005, 12:15 PM
You should really go to the link.
Sherwood
Old 06-29-2005, 12:22 PM
Carl83911's Avatar
Cheers,
thanks for the link. now I understand.
Carl,
Old 06-29-2005, 12:29 PM
Bill Verburg's Avatar
Sherwood
Agreed
Bill Verburg
Old 06-29-2005, 01:16 PM
Stranger on the Internet
patkeefe's Avatar
Carl:
As per Shewood and Bill V., that is a pretty definitive link. I have it on four hard drives and a print copy hanging on the garage wall.
Pat
Patrick E. Keefe
78 SC
Old 06-29-2005, 03:22 PM
