I am working on a 1982 Targa 911. Took it down the road for a test drive after replacing the fuel injector seals and the Tach and Radio started doing strange things. The Tack needle jumped up to 8K RPM and kinda bounced around while cruising at 60MPH in 5th gear. At the same time the Radio started loosing electrical power and would go on and shut off. I wouldn't think the radio and tach are electrically related in anyway, but when this problem occurs both instruments start doing these unusual things.
Any suggestions? Thanks, Keith
Sounds like voltage regulator is spiking. Did you disturb any electrical connections?
I did not disturb any wiring at all. The owner recently installed a aftermarket radio. But I have done nothing to the car electrically.
Still Doin Time
Could be ground OR power poor connection(s). The FIRST place to check is the LAST place someone had their fingers in. This is a mechanics mantra because it's true!
'15 Dodge - 'Dango R/T Hauls groceries and Kinda Hauls *ss '07 Jeep SRT-8 - Hauls groceries and Hauls *ss Sold '85 Guards Red Targa - Almost finished after 17 years '95 Road King w/117ci - No time to ride, see above '77 Sportster Pro-Street Drag Bike w/93ci - Sold |
electrical problem
The owner had the engine rebuilt about a year ago. Could be something that has just now surfaced from a improperly placed wire / loose connection. I'm gonna trace down the radio and tach wiring first. This car has a new battery and if the car is not driven every day, the battery will go dead. Could be a short somewhere too i guess. I charged the battery and drove it about 20 miles the other day but battery didnt charge enough to start engine after that drive. Thought that was unusual.
Thanks, Keith |
Somatic Negative Optimist
Time to check the voltage output on your alternator AND have the battery tested; it sounds like your alternator, or regulator, is screwy.
Charge your battery with a charger, NOT on the car. Have it tested at a shop; even a new battery can go south. Voltage should be around ~12V standing, and ~14V when running.
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
gunter gave good advice..
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
