If you are going this far why not spring a few extra bucks for a true heat exchanger to compliment the new oil lines. Most people agree that the trombone is not very effective an you can buy a trombone replacement from Mocal for as little as $300.00 http://www.batinc.net/porsche.htm Having said that I'll share a little experience I had. I owned a warm running SC several years ago. As I have said in earlier posts, in Tampa rush hour traffic with the A/C blasting, it regularly got to 250F. Plus once it got hot, the ONLY way too get that heat out of the oil was to shut the car off. I bought one of these Mocal trombone replacement kits and I was originally a little disappointed with the results. The car still got hot, about 230, and I really began to worry. Despite more cooling capacity than the trombone, air flow in that fender area is not good. I then added an electric fan which improved airflow somewhat. When I ran the car hard it still got hot BUT the most important thing was that the car would cool right down to 210-215 when I backed out of it. From that perspective, it was a big improvement. So, you may want to consider this as I think you'll be disappointed with the trombone by itself. Don
72T Coupe - SOLD :-( |
i think this is a little bit of a conduction vs convection argument.
As you increase the airflow, the time the air spends next to a cylinder is less so conductive cooling is lessened. Convective cooling should increase but it is limited. If you pass this limit, then all you are really doing is adding more combustion events.
Paul 1980 911SC Targa - Sold 1972 914 - Sold |
huh??
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
Information Junky
When pushing cooling air, you definitely want to stay OUT of the supersonic flows. . . they *will* add heat.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
that I believe - tho I have spent some fair amt. of time in libraries to find the 1930's pre-supersonic flow analyses....
it was the 'conduction' comment above that got a 'huh'
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 07-10-2005 at 09:45 AM.. |
Don
I think you're right Don. That is what I've found in all my unscientific runs.
Also, according to Bruce Andersen, my fan has a 1.67:1 Ratio.
Information Junky
Conduction, to the air (as happens for convective cooling) will have increasingly MORE air to transfer heat to, as the air velocity (volume) is increased. Sure, each molecule of air is spending less time picking-up heat, but that is a good thing, as heat transfer happens faster, when the difference in temp's is greater. ...that is; 10mol of air(say 1 mol per second) in 'heat-transfer-contact' will transfer more heat than the "slower moving" of leaving one mol of air in contact for ten seconds (assuming the same starting temp's) --sorry isf that was tough to follow. Point is, heat tranfer rate is driven by temp differences. . . and as one mass (say a mol of air) lingers to take on heat, its temp is then closer to what it's taking heat from . .. .and thus becomes less efficient at taking heat.
