Gon fix it with me hammer
oil temp sensor check?
does anyone know what values the Oil temp sensor should read out?
i'm trying to test mine , but not sure if it's my sending unit , or my vdo gauge that's not working so i figured i'll put the sending unit in boiling water that should be 60 degrees C and then read out the sensor with an resistance meter is there a chart for that? alternatively , can i test the gauge by putting a potentio meter on it, and checking the values on the dial , vs the current on the wire?? so far my gauge stays at 0 when the engine is warm but when i put current on the gauge, the needle does max out
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
AFIK boiling water is 100 degrees C
Peter '13 981S '73 911T '05 996 4S cab, now gone '70 911S Targa, now gone |
Riiight, swiss cheese for memory....
Peter, do you have one of those sending units laying around for little test? putting one in boiling water, and see how it's reading out?
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 Last edited by svandamme; 07-11-2005 at 08:16 AM.. |
I must have one somewhere, I will have a look tonight
svandamme,
I ran a test on a new early VDO sender in a pan of cooking oil on a hotplate ... using a thermocouple probe and Fluke 52 thermometer, and measured the resistance at 10°F intervals from 70°F to 300°F. If you substitute a 1000 Ohm potentiometer for your sensor ... you could test your gauge by sweeping the range, and temporarily disconnecting the pot. to measure the resistance that produces readings at your gauge marked points. The early gauge was never off by more than 4°F over the entire range ... compared to the Fluke 52 thermometer! Temp - °F -- Sensor Ohms: 70 1148 75 1000 80 918 90 756 100 607 110 504 120 424 130 357 140 301 150 260 160 219 170 189 180 162 190 142 200 122 210 108 220 92.4 230 82.2 240 73.2 250 64.2 260 57.6 270 51.2 280 43.8 290 39.6 300 35.4
Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder' |
brilliant !! thanks Warren
don't have a potentiometer handy , but i can easely check my sending unit with this chart
