Finishing a fiberglass bumper
I would like to get advice/input on the proper way to finish a f-glass bumper.
What grit to sand with? Sand in stages (varying grits)? Primer needed?...type recommended It's for a track car so I am not looking for concourse level work. I'll be doing it in my garage and don't mind investing some time to get it to look nice but would like to spend less than one day on it. Any experience you have would be appreciated. Thanks.
'83 SC |
I'm going to assume the bumper is in good shape with no spider cracks, chips etc. I would sand with 220 to 320 to start and give the bumper a good sanding. Then I would do the same with some 800 to 1000 grit and after that clean with prep solvent and then hit it with some automotive primer. You want to put down several coats this will help fill in small imperfections. Once dry hit it one more time with some 1000 grit,clean with prep sol and lay down your paint. This should give good results.
2002 Boxster S . Arctic silver + black top/int. Jake Raby 3.6 SS engine " the beast ". GT3 front bumper, GT3 side skirts and GT3 TEK rear diffuser. 1999 996 C4 coupe black/grey with FSI 3.8 engine . Rear diffuser , front spoiler lip with ducktail spoiler . |
Thanks. Yes it's in very good condition.
'83 SC |
