MovOvr1's Avatar
Playing around today....but have questions!
Here are some pictures of the car while I was out playing today (golf that is). Took the pics on a whim.
The question I have is that I stayed on the range about an hour and the car would not start. The ol' crankin and crankin' but no startin'. Pulled the fuel pump fuses (or are they relays...the big black round things up front?) and cranked it and it started right up. My accumulator is about 1 1/2 years old as well as filter ect. I can't think of what it is that is causing it.
Any help is appreciated.
Brian
Brian
BLK 79-930
Old 07-17-2005, 08:38 PM
bigchillcar's Avatar
well..wouldn't you be pissed too if your owner were out driving golf balls instead of doing the right thing and driving the piss out of you? (so to speak..)
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008
www.friendsofwarren.com
1990 964 C4 Cabriolet (current)
1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold)
Old 07-17-2005, 09:17 PM
I had a proplem with my SC on a drive from San Diego to Seattle, I pulled over in the middle of nowhere to take a nap and when I awoke the darn thing would not start. I shook and checked many things but what it ended up being was the wire plug on the left side of the engine compartment aft of the CDI down where the fuses are. ( sorry I dont have a manual with me to give you a more specific answer)
1983 911SC
1977 911S "parting out"
Old 07-17-2005, 09:21 PM
O Beautiful Beautiful car
1983 911SC
Old 07-17-2005, 09:22 PM
MovOvr1's Avatar
ryan
Now that is funny! I will apologize in the morning.
Brian
Brian
BLK 79-930
Old 07-17-2005, 09:25 PM
DavidI's Avatar
What about the fuel pump check valve? It is usually that or the accumulator.
Good luck, David
99 996 C4
11 Panamera 4S
83 SC Targa converted to a 964 cab (sold)
67 912 (sold)
58 Karmann Ghia choptop (traded for the 912)
Old 07-17-2005, 11:19 PM
MovOvr1's Avatar
Where is the check valve? and is it easy to replace?
Brian
Brian
BLK 79-930
Old 07-18-2005, 03:14 AM
check valve should be attached at the business end of the fuel pump. it is either mounted up front near the fuel tank or underneath the drivers side rear of the car near the wheel well..it looks like a 'fitting' attached to the end of it leading to the fuel line. good luck.
ryan
Old 07-18-2005, 03:40 PM
MovOvr1's Avatar
THanks...I will do some investigating this weekend.
Brian
Brian
BLK 79-930
Old 07-18-2005, 07:38 PM
