Ozz,
Good work!
How are you finding the Rennshifter? Looks a simple bolt on application. How has it improved things?
Simon
85' Carrera 3.2
02' Mazda MX5
Old 08-30-2005, 05:16 PM
bigrubberjeep's Avatar
Very nice - Only thing I would change would be maybe the rings around the headlights, black was the OG color. Might as well go with H4's while your at it. Other then that, I am very envious.
85 911 SuperSport
No more looking! The jewel is mine!
89 Jeep Wrangler
A jewel in the rough
2000 Grand Cherokee
Family Wagon with Jewels on board
Old 08-30-2005, 06:35 PM
ozz ozz is offline
ozz's Avatar
Simon,
The Rennshifter is working out great and is a simple bolt in installation with just a few adjustments. It has reduced shifter throw and has a very positive feel going between gears as well as a nice reverse lockout. In the past, I'd miss a (down) shift from time to time and I've been running this shifter since May and haven't missed a shift yet!! I'm very pleased with it.
bigrubberjeep - thanks for the heads up on the headlight ring color!
Gary Osborne
Chardon, Ohio
___________
74 911 IROC
98 Panoz GTWC
Old 08-31-2005, 07:10 AM
Question - how did your roll bar mount to the car?
85 911 SuperSport
89 Jeep Wrangler
2000 Grand Cherokee
Old 01-26-2006, 11:54 AM
durn for'ner
livi's Avatar
Awesome!
Am I right believing they only made 12 IROC 911īs for that Championship ! And that among others Mark Donahue drove them ?
They must be immensely collectible today. Anyone know how much an original would be worth ?
Markus
Resident Fluffer
Carrera '85
Old 01-26-2006, 12:07 PM
ozz ozz is offline
ozz's Avatar
livi - they made 14 in total. I've seen a couple running around SVRA events so, I'm guessing they are collectible but, not Barrett-Jackson collectible if you know what I mean. Just guessing here.
Bigrubberjeep - I see you pulled up my brake cooling thread from this time last year too - ah the memories of the frigid garage.
In any case, mine is a Saftey Devices cage - the main roll bar hoop mounts to the longitudinals of the car. They provide steel plates bent to conform to the longitudinas with 4 welded nuts per plate. You set the hoop (and the rest of the cage), mark and place the nut plates, drill holes to allow nuts to drop into the holes and the plate to sit relatively flush. I used JB weld to "tack" the plates in place with the entire cage installed to be sure all would line up later. Took the cage out, had the plates welded to the car and reinstalled the cage. Getting 16 bolts to line up with the welded plates and nuts was a PITA but, eventaully got it done. Hope this helps.
Gary Osborne
Chardon, Ohio
___________
74 911 IROC
98 Panoz GTWC
Old 01-26-2006, 12:20 PM
}{arlequin's Avatar
very nice. have you dyno'd the car yet?
dave
1973,5
Old 01-26-2006, 12:28 PM
ozz ozz is offline
ozz's Avatar
dave - No, I didn't get to that last season and hope to so this spring. I'll update this thread when I get the results.
Gary Osborne
Chardon, Ohio
___________
74 911 IROC
98 Panoz GTWC
Old 01-26-2006, 01:07 PM
jtkkz's Avatar
Which roll bar did you use?
Please give me more info on the rollbar you used on your car
thanks
Early Porsche Reproduction Products:
http://sycipworks.tripod.com/
Old 01-26-2006, 01:37 PM
jmz jmz is online now
jmz's Avatar
great car. How does it run? I've got almost the same engine but only 9.3:1 and weber 40s w/ 36mm venturi...plenty of carb for the motor.
Mine too is twin plugged but don't need it yet.
-Jay '74 Mexico Blue 911 3.0 EFI (Fast and Loud)
'70 914/6 Race Car (Faster and Louder)
'71 73RSR tribute vintage race car 3.0
'68 SWB 911T "RENNRAT" 2.8 twin plug/915 gearbox
'81 Magenta IROC clone in progress 3.6 varioram/G50
Old 01-26-2006, 03:10 PM
ozz ozz is offline
ozz's Avatar
jtkkz - The roll cage is from Saftey Devices for a 911 coupe. The folks at Stable Energies can give you all the info.
jmz - runs great and pulls strong from about 3500 to redline at 7000 The car is way faster than the driver . For now anyway.
Only issue has been that I've had trouble with the fuel pump in the rear of the car. I've used both Carter and Mallory pumps and have not had great reliability with either (needs to be closer to the tank) so I decided to put a fuel cell in it this year over the winter with a Walbro pump and scavange box in the cell. A little safer maybe given I have all glass bumper up front and, the pump being in the tank ought to resolve my fuel pressure problems.
Gary Osborne
Chardon, Ohio
___________
74 911 IROC
98 Panoz GTWC
Old 01-26-2006, 05:31 PM
