Yet another A/C question
Is anyone using a rear condenser and an underbody (static) without a front condenser? If so, are you happy with it? I'm trying to decide if I want to cut my 76 to add a front condenser with an underbelly and rear condenser, or just use rear condenser and underbelly. I will be using a Seiko compressor and R-12 refrigerant with new barrier hoses.
Anyone??
Designer King
When I had my AC in, I was using the rear condenser only w/ the old York compressor. It worked OK for our summers here, which usually get into the high eighties w/ a humidex reading (feels like) low 100s.
for maybe half the month of august.
Paul Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9 Never leave well enough alone |
