ischmitz's Avatar
Send a message via Skype™ to ischmitz
Window tint removal
Does anyone have have some good advice on how to remove the window tint on front side windows? How tough is the job and what worked best for you.
Cheers,
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 09-07-2005, 08:20 AM
I used a steamer (regular household steamer to get rid of wrinkles) to heat the tinted film, then easily peeled it off. In my case there were two layers of film so be careful to try and peel both together.
Max Hofer
1985 911 Turbo-Look
1985 944 NA
Santiago - CHILE
Old 09-07-2005, 08:32 AM
Non Compos Mentis
Once you peel the film off by hand, the sticky residue will come off easily with xylene or MEK. Just don't get synthetic solvents where you don't want them. Wet a rag and start wiping.
You should be able to lift a corner with a sharp knife or razor to get started.
Here's a couple of good tips: Any tips on removing window tint??
Warren & Ron, may you rest in Peace.
Old 09-07-2005, 08:43 AM
khamul02's Avatar
I talked to a pro about this & they use a steamer.
Tom Hutchinson
80 Targa / 81 Coupe / 71 Targa (in Porsche heaven)
My Garage Build: https://youtu.be/H0n_NwEQVbs
"If one does not fail at times, then one has not challenged himself." Ferdinand Porsche
Old 09-07-2005, 08:44 AM
