Where to find factory spring plate?
Okay, I figured out the part numbers I need for my spring plates. I go to my local dealer. The parts guy is always willing to help me obtain even the smallest of parts. He checks availability. There is only ONE, and it's in Germany. :mad:
Any idea where I can obtain another NOS spring plate? :confused: |
I have a set I just took off my SC...
New spring plates. For a Carrera.
Nothing personal.... |
You mean these are NLA at this time??
http://forums.pelicanparts.com/uploa...1122514387.jpg These were a better buy than Google. j.p. |
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_suspen_pg14.htm#item58 |
Perhaps I'm looking at the wrong line item, but those look like Weltmeister adjustable springs plates rather than factory units.
Sorry, here is the correct link:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_suspen_pg7.htm#item25 I meant to post the first link to the Sway-Aways as a cheaper alternative to the factory pieces. Why not go the used factory SP route though? For the price you can pick up a good used OE pair for, you can have them cleaned up, re-plated, and install a set of neatrix or even poly-bronze bushings for nearly half the cost of a new OE set. |
Yes, I'm being told the arms for 74 - 89 are NLA.
As for used parts... Well, I have used parts. I want new parts. Or at least new factory equivalent type parts. After all, the factory parts lasted through almost twenty years of neglect without a single consideration. They didn't wear quickly like netrix, squeak like poly, or need constant greasing like bronze bushings. Bottom line: If I could install a set of NOS spring plates, I could drive the car until 2025 without worry... |
Oh, for those unaware. NOS = New Old Stock.
It's a common automotive term for parts the factory has for vehicles they no longer produce. |
Mine are due for a change after 21 years of service. Considering they're NLA, I'll save the OEM units and go with WEVO units. The OEM's are best suited for a restoration job.
Soon the A-arms will become NLA, may be a good time to buy a pair and stash them; that's if you plan on keeping a 74-89 car for a long time. j.p. |
j.p.
Not necessarily. The 915 short shift kit went NLA 6 months ago & just magically re-appeared. If they can sell them, they will build them. That said, new springplates aren't at the top of most people's wishlists. Except maybe the Capt's. I hear you about keepin' it stock. I did go to Neatrix & there were nice improvements. But, they are not bonded like stock (the glue is useless & pointless). Ian |
...I'm thnking WEVO now. It looks like the best option available.
I e-mailed Hayden, but have not heard back if he makes them for Carreras. |
Re: Where to find factory spring plate?
You could try another German company, Mittelmotor, never used them myself but i know others who have. http://www.mittelmotor.de/english/startenglish.htm go to online shop.... Suppose it depends on how keen you are on fitting OEM spring plates - approx $400 per side, plus delivery etc Cheers, SP |
http://forums.pelicanparts.com/porsche-911-technical-forum/213626-wevo-wow.html |
SmileWavy |
Back in May of this year, I asked this company http://www.jzmachtech.com (possibly the best regarded independent in the UK) about OEM spring plates and they reckoned they could get them in from Germany for approx 200GBP each Suggest you give them a call too Cheers for now Shirish |
Rob:
I have found new OEM spring plate for your car,let me know if you're interest. Regards, j.p. |
You found one, or two?
Either way, you don't need to buy them in pairs.
j.p. |
Rob:
You have a PM. j.p. |
| All times are GMT -8. The time now is 11:38 AM. |
