techguy's Avatar
Porsche Crest Compression Testing a 2.7 with Carbs
Hey Guys,
Bought a nice compression tester last fall and with the weather warming up this weekend I figured I would try it out on the car. Obviously I am going to disable the fuel pump but have questions on the engine prep before the test.
My thoughts are to run the test with a cold motor and all plugs in. Is this correct? I figure with the plugs in the back pressure would be more like actual operating conditions?? I have also read that the plugs should be removed cold due to expansion and possible damage to threads on a warm engine???
What procedures are correct?
TechGuy
1972 Targa 911T/S 2.7
PCA Upper Canada Region
Old 03-05-2004, 12:33 PM
A Quiet Boom's Avatar
I've always done compression tests with all the plugs removed for two reasons. First the tester screws into the spark plug hole so removing them makes sense and second the starter can spin the engine more easily with them removed so the readings are usually more accurate.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 03-05-2004, 01:26 PM
Oops, one more thing. Yes it is better to remove the plugs cold on ANY aluminum cyl. head.
Old 03-05-2004, 01:27 PM
I like to unplug the CD,
keep throttle WOT
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-05-2004, 02:25 PM
Warm engine to operating temperature
Remove all plugs
Ground the coil wire (remove from distributor cap)
Open throttle
Crank engine for 4 compression strokes (go 8 if you have an early S or with agressive cams); record the last reading
Sherwood
Old 03-05-2004, 03:30 PM
techguy's Avatar
This is tomorrows job finally.
The big question, hot or cold when running test? Plugs in or out?
TechGuy
Old 07-30-2005, 09:16 PM
normal operating temp, plugs out, crank each cylinder about 10 pumps or until the gauge stops moving.
206 637 4071
Old 07-30-2005, 09:49 PM
techguy's Avatar
Should I back the plugs out a bit prior to running the motor up so the removal is easier and I do not damage the threads?
TechGuy
Old 07-31-2005, 08:51 AM
