mattduncan's Avatar
quick alternator question
Im in the middle of putting my 82' SC engine back together and have an alternator wiring question (I didn't take pictures ).
As looking at the back of the alternator, the big red wire connects to 5 o'clock. Which one does the blue wire connect too? 7 or 11 o'clock?
Oh ya, i've checked the wiring diagram and unfortunatly the alternator is labled D- in the middle of the plate so I can't tell if which terminal is D- and which is D+.
Matt
Old 07-29-2005, 06:47 PM
mattduncan's Avatar
OK, I really do need help. I have the engine running but I must have hooked it up wrong. There is no voltage at the battery (charging voltage).
PLEASSSSSEEE Help... I've checked everywhere with no luck. I have to go racing soon and need to get it fixed!!
Old 08-11-2005, 01:35 PM
If I was home right now, I could tell you quickly. I have my alternator out and it's marked where each wire goes. I'll try and respond this evening.
Michael
1999 996 C4 Cabriolet
1997 BMW M3 (Hail)
1985 928 S (Sold)
1982 SC Targa (Sold)
Old 08-11-2005, 03:00 PM
mattduncan's Avatar
"If I was home right now, I could tell you quickly. I have my alternator out and it's marked where each wire goes. I'll try and respond this evening."
Michael,
Thank you, thank you and thanks again...this is driving me batty..
Old 08-11-2005, 03:32 PM
911mot's Avatar
Does the ignition light come on?
If not, check the bulb before pulling the alternator. A blown bulb stops the alternator from charging.
If it comes on and goes out when started but still doesn't charge at the battery, check you've got a good clean connection to the starter motor solenoid feed terminal. There should be two thick wires, one carries charge from the alternator, the other main feed straight from the battery, hence the need for a good connection.
If the light comes on and doesn't go out on starting (or glows dimly) you need to check that (1) the blue wire is on the correct terminal of the alternator and (2) that the connection in the multiplug that hooks it back into the cars wiring loom is good.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 08-11-2005, 03:50 PM
911mot's Avatar
Also aren't the D- and D+ terminals different sizes...so the blue wire would only fit the right (correct) one?
1984 3.2 Carrera
Old 08-11-2005, 03:52 PM
mattduncan's Avatar
Thats what I thought also when I took it apart..."Won't be hard to remember which one, it only fits on one.". But for some #%^@# reason, I have it wrong and don't want to tear it down again after I fix it this time....
The light is always on. Good bulb. Ignition in any "on" position or the engine running. Thanks for that input though, I didn't know that about the bulb. That could drive a person crazy trying to troublshoot a different problem.
Old 08-11-2005, 04:08 PM
I'm with Bill
Rick V's Avatar
acording to my bentley manual you should have 3 wires on the alt.
1Big red puppy to b+
1 blue wire to d+which goes to the alt warning light and the d+ side of the regulator(if externaly regulated)1 brown wire to the d- this goes to the eletrical componants (and the d- side of the regulator if external)
It APEARES that the lug you quest is at 7 oclock
good luck and happy racing
Old 08-11-2005, 04:12 PM
jdowty3's Avatar
You probably switched the the 2 wires that go to the regular size terminal studs. I did the same thing when I put my motor back together last spring.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 08-11-2005, 04:24 PM
mattduncan's Avatar
I have the bently also, and studied it till I'm brain dead. My problem is I don't have a D+ and D-1 stamped on the back, just D-1 right in the middle. Same with the B side. So I don't know if it's refering to the top or bottom post.
Old 08-11-2005, 04:30 PM
I'm with Bill
Rick V's Avatar
can you start the car? If so you should have B+ on the d+ lug and a nothing on the other lug. The one producing B+ is the one you need. the other lug should be a ground or D-. Use a dvom and not a test light
Old 08-11-2005, 04:38 PM
mattduncan's Avatar
Can you explain that in stupid terms? I don't get it... What is a dvom? What does "producing B+" mean? Does it mean possitive current?
Old 08-11-2005, 05:10 PM
Need help installing alternator
Old 08-11-2005, 05:15 PM
I'm with Bill
Rick V's Avatar
Ok dvom is a digital volt ohm meter. I recomend the use of this because you will get exact volt readings. New test lights will light up with as little as 2 volts. they are designed to give positive or neg. reagings only they don't convey voltage.
B+= batt. voltage positive B-=bettery voltage neg.
D+ or D- is switched or regulated voltage. it is used to control something like a light or regulator as in your case. it will supply the info the car needs to charge the batt(B+) and run the car.
Old 08-11-2005, 05:52 PM
jdowty3's Avatar
The large red wire and the normal brown wire connect to the terminal by the regulator. The blue wire goes to the other normal size terminal stud opposite the regulator.
Jim Dowty
Gruppe B #309
Old 08-11-2005, 06:14 PM
