Ptoscano's Avatar
Send a message via Yahoo to Ptoscano
Spacer question
When re installing spacers do I need to torque them ? Is so what #. Should I use some sort of lock tite ? Just curious
2012 XC90- wifey
2011 BMW 535I -Daily Driver
911/964 Widebody Cabriolet-Protosport Stage 1.5 Turbo
Old 08-02-2005, 06:20 AM
DW SD's Avatar
To what spacers are you referring? Maybe a picture would help.
Doug
1971 RSR - interpretation
Old 08-02-2005, 07:21 AM
Ptoscano's Avatar
wheel spacers
2012 XC90- wifey
Old 08-02-2005, 07:41 AM
DW SD's Avatar
There are different varieties. Some that are actually adaptors, which bolt to the existing hub and have their own studs. Some that are true spacers and just slip - on to the studs. The latter does not use loctite, but should be torqued.
Again, maybe a picture would help. Hard to read your mind.
Doug
Old 08-02-2005, 08:25 AM
Ptoscano's Avatar
sorry dont have pic right now but they are spacers with studs-that bolt to existing hubs
2012 XC90- wifey
Old 08-02-2005, 11:46 AM
Non Compos Mentis
Torque them just like wheels.
Old 08-02-2005, 11:49 AM
Ptoscano's Avatar
Anything specific on torque
2012 XC90- wifey
Old 08-02-2005, 11:55 AM
DW SD's Avatar
I'm thinking 70 to 75 ft-lbs, but someone else should clarify.
Old 08-02-2005, 12:47 PM
Ptoscano's Avatar
tx
2012 XC90- wifey
Old 08-02-2005, 01:11 PM
Early_S_Man's Avatar
Porsche Crest
All 911 lug nuts prior to 964 have 94 lb-ft torque spec!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 08-02-2005, 01:25 PM
911SCfanatic's Avatar
I was waiting in great anticipation of Warren diving from the top turnbuckle to drive an elbow into DWSD's temple. Thank you for the show, Warren!
Bill G.
'68 911 Ossi Blue coupe
Old 08-02-2005, 01:56 PM
DW SD's Avatar
OUCH - some times we all learn lessons the hard way - that hurt my temple!
Kidding aside, I believe I did suggest someone should clarify.
Old 08-02-2005, 02:01 PM
Definitely no knock intended on you or Warren, DWSD. I just get a kick out of seeing Warren in action. Don't know why...it just makes me smile.
Bill G.
Old 08-02-2005, 02:05 PM
DW SD's Avatar
No question - Warren is the MAN! I'm not trying to be Warren, either. Just trying to help. I will qualify my answers if I'm not 100% sure.
Doug
Old 08-02-2005, 02:07 PM
