Once a friend of Cliff
undercoating restoration
using my trailer to haul the 911 for the 1st time i experienced some scraping of the body undercoating. a line on each side about 2' long that went all the way down to the bare metal.
my plan is as follows, i will get my wire wheel grinder and hit the scared areas to remove all the loose undercoating material still present, and any surface rust that may have developed in the week or so before i can get under it. then i was going to get some of the por-15 http://www.pelicanparts.com/cgi-bin/ksearch/pel_search.cgi?command=DWsearch&description=por15&I1.x=9&I1.y=10 the "metal ready" type, the 1st one in the catalog search ive attached. follow the application directions and seal it before it gets any rust. sound approach/method/logic? tia
78SC PRC Spec911 (sold 12/15) https://www.youtube.com/watch?v=f7I6HCCKrVQ Now gone: 03 996TT/75 slicklid 3.oL carb'd hotrod 15 Rubicon JK/07.5 LMM Duramax 4x/86 Ski Nautique Correct Craft |
So, you'd use Metal ready to etch and neutralize and then POR-15 to seal. Followed by Body Schutz (Undercoating). Right?
Warren & Ron, may you rest in Peace. |
BTW, I just realized POR-15 in headquartered in Morristown, NJ. Right next door to me. Maybe I'll go snap some pics and ask how to remove from hands when dry.
Hey ...!
Post some Pic's of the Proccess..! Vic
i just noticed that was not the product for the application. thats is all i found on the search of the parts area here at PP. anyone have a link to the stuff i need to apply?
Isn't the undercoating a spray-on product called Wurth Body-Schutz, or something like that?
1984 Targa |
Scott, I believe Toby wants to protect the bare metal before he sprays the Schutz.
Here's the POR-15 you most likely want: http://www.pelicanparts.com/catalog/shopcart/CARE/POR_CARE_por15A_pg1.htm A pint should be fine for your job.
thank you rick, thats the poop.
