SLR SLR is offline
SLR
Removing door window frames?
I need to repaint the door frames on my 911, (the black bits) there are bolts at ether end and screws at the top. I want to leave the glass in place.
is it hard to get the rubber seal back over the 1/4 light glass when reinstalling the frame?
Thanks Steve.
Old 08-01-2005, 03:11 AM
Re: Removing door window frames?
Originally posted by SLR
1/4 light glass
huh ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 08-01-2005, 03:48 AM
tops911's Avatar
You have to take the door panel off. Inside the door are some bolts ( or screws). Now that I think about it I think the screws are accessable on the out side of the door under plastic plugs, I'm not sure now. When you have them out just lift up on the frame the door glass will stay. the "vent" glass will come out with the frame. The seals are easy to replace. I've done this, The paint did not work for me, even the self etching primer failed to stick. I will do it again, but I'll get the frames powder coated.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel
Old 08-01-2005, 05:43 AM
There is one bolt inside the door that must be removed, so the door panels must come off. The other 5 bolts are under 20mm placstic plugs in the door frame.
69 911 2.3Ez
85 928S
Old 08-01-2005, 11:13 AM
