g50 into 84 carrera?
who makes a conversion flywheel to install on a short bell housing G50 for a 3.2? The 3.6 flywheel will not work with the 3.2 dme
anyone with personal experience?
thanks
Old 12-22-2004, 01:15 PM
juan ruiz's Avatar
I think Patrick Motorssports does
10.76@139-1/4 mile
0-1 mile 193MPH
I Love to Shine Cars
Old 12-22-2004, 01:38 PM
Irrationally exuberant
ChrisBennet's Avatar
A while back I loaned "Mike the mechanic" a scope to get to the bottom of some problems he was having with a Patrick pressure plate for just the sort of G50 conversion you are talking about. Long story short, the pressure plate didn't (and couldn't) work because it interfered with the speed and reference sensor signals. I know you asked about the Patrick flywheel but you might want to contact Mike before you buy.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 12-22-2004, 02:37 PM
Bill Verburg's Avatar
Patrick does make the conversion flywheels, I have also heard of some issues w/ them. I know that Steve Timmins no longer uses them. He has been sourcing his from Germany.
Bill Verburg
Old 12-22-2004, 03:13 PM
here is the problem: When you shorten the bell housing on the G50, you end up using a 930 turbo flywheel that gets all the teeth machined using the outer circumference. Now where do you put the other sensor pin? Logic tells you the pressure plate BUT with the pressure plate installed, you end up with one of the cast in spaces on the pp where the sensor should reside. What to do? 2 solutions- 1) drill and tap new holes for the pp to sit , drill and tap the pp for the pin OR 2) weld a pin on the inside of the toothed ring so it protrudes into the gap. In either case you will have to modify the sensor support so the sensors are set in depth and height to correspond with the pin and teeth. A pita? definitely, but it will work with either method
We are not worried about the minimal amount of extra weight the welded or threaded in pin gives the assembly. Care should also be given on the total outer diameter, inc the pin, so it clears the bell housing
1970 914-6 street"evil cockaroach"
1970 911 Targa "ST"
Jade Green IROC Tribute (ready to race)
Old 12-22-2004, 03:40 PM
You should talk to Mike but here is what I recall:
Mike was using a Centerforce pressure plate as part of Patrick's G50 conversion kit. The aluminum pressure plate is attached to the steel friction section by three steel lugs, and those lugs produce an undesired/bogus signal in one or both or the sensors. He was never able to get it to work and if I remember correctly Patrick was never able to give him the name of anyone who had.
-Chris
Old 12-22-2004, 04:12 PM
juan ruiz's Avatar
ChrisBennet
you are correct that was his problem , according to him that was their very first set up patrick did, I did mention him ( patrick) as he is the only source I know, maybe Mike will chime in and clear the air.
10.76@139-1/4 mile
0-1 mile 193MPH
Old 12-22-2004, 04:41 PM
hi chris
we are trying something and will know in about an hour if our experiment is sucessful. will post results later
1970 911 Targa "ST"
Old 12-22-2004, 05:04 PM
okay, method #2 worked with an additional mod- if you look at the steel lugs on the pressure plate, they are pretty heavy construction. we removed about 1.5 mm of material. Ths coupled with the "pin" on a flange we welded to the inside of the outer toothed ring gave us enough clearance so the sensor no longer picks up the lugs. Its running great! Sorry- no pics- as we were behind in getting this done
1970 911 Targa "ST"
Old 12-22-2004, 05:55 PM
did anyone else do this and get great results?
How much does it run?
Williamknightperformance.com
Perfectpower.com
Old 02-22-2005, 11:04 PM
Tre Cup, I am mating a short bell housing 930 trans to my 84 3.2 turbo
Can I use a aftermarket Early 930pp clutch disk and TO Bearing
and buy a 87-89 g50 flywheel and do the same process you have done.
Do you have any picks of the machining?
It would be very helpful
Thank You
Perfectpower.com
Old 08-06-2005, 11:44 AM
Any one else can help me out?
Perfectpower.com
Old 08-08-2005, 08:41 AM
