Interesting. No time to check mine but wonder if this is the problem? Wouldnt this show up on the OBDII readers?
JoeA |
It should throw a code if completly failed like mine but won,t be seen as a problem if the resistance values are off. that senario would only change the injection strategy to richer or leaner than required.
My '97 3.6 is in an early '89 [G-50] and starts VERY quickly. Always has...It was bought from Timmins, new flywheel [single sensor as opposed to dual sensored 3.2 flywheel].
My only problem has been the fall-off of rpm when letting off the accelarator pedal. It doesn't stall, it just falls way off then the engine knocks a little and comes back up to idle. ??? Drums |
