3.6 conversion slow to start
I have my 1990 3.6 installed and running in a 1980SC but a few questions.1) It seems to crank too long before starting. Is there anything holding pressure in the fuel rail or does the system rely on the pump immediately pressurizing the injectors when the position sensor detects rotation?
2) Idle oil pressure is 1.5 to 2 bar but pressure peaks at 3.5 bar at about 3500 RPM hot , no higher when reved .Oil is fresh mix of 20w50 Dino and 15w50 synthetic. Is there a compatability issue with the 3.6 sender and the 1980 guage? I haven,t checked with a mechanical guage yet.
3) Where is the O2 sensor plug ? Is it the round 3 pin on the driver,s side near the plug bracket and coil feeds?
1980 911 SC 3.6 coupe sold
1995 993 coupe
1966 Mustang Shelby clone
1964 Corvair Spyder Turbo gone
2012 Boss 302
Old 08-08-2005, 07:05 PM
Re: 3.6 conversion slow to start
John,
I'm no help other than to say that my 3.6 conversion does the same thing. You got me thinking... if you turn the key to 'on' for a few seconds (activating the fuel pump?) and then crank... does it start right up then? Mine's on stands at the moment. I'll do that when it hits the ground.
Hopefully someone brighter than me chimes in on this.
-bernie
Old 08-08-2005, 07:54 PM
The second stage of the DME relay turns on the pump when the crank sensor detects rotation. The pump doesn,t run otherwise. I want to know if there is any one way setup that would hold line pressure like the pressure accumulator in the CIS system?
1995 993 coupe
2012 Boss 302
Old 08-08-2005, 08:04 PM
Obviously, your already way ahead of me...
Old 08-08-2005, 08:09 PM
Author of "101 Projects"
Wayne 962's Avatar
I'm thinking something else is wrong. Pressure should be almost instantaneous (like any modern car). Have you checked the fuel pressures in the rail?
-Wayne
Bill Verburg's Avatar
They should start instantly.
Bill Verburg
Old 08-08-2005, 08:15 PM
My car does the same thing and I haven't been able to find out why the car doesn't start up right away. (I have a late '91 3.6L) The fuel does not seem to hold any line pressure. The only time it starts up right away is when I drive it the day or two before I start the car again; any longer than a week and the car is real slow to fire up.
- James
1975 3.6 RS
2015 F10 535i
2011 911 C2
Old 08-08-2005, 08:28 PM
bump for the morning crew...
Old 08-09-2005, 06:22 AM
I can leave mine all winter it still starts immediately(both setups that I have had). Have you guys got the fuel accumulator hooked up? Pressure regulator and vacuum valve?
Bill Verburg
Old 08-09-2005, 06:27 AM
I removed the 3.0 with it,s accumulator ,filter etc. I ran a new steel fuel line from the tunnel to a new filter location on the right side ahead of the oil tank then into the right side rail. The return is from the left side back into the SC steel line . The stock 3.6 pressure reg is there . What vacuum valve do you have in mind?
1995 993 coupe
2012 Boss 302
Old 08-09-2005, 06:42 AM
'90 964 fuel
vacuum control is #24, pressure regulator is #17
Bill Verburg
Old 08-09-2005, 07:01 AM
Both are there What is the function of #24? The regulator may be bleeding away pressure when stopped. I will try pinching the return hose and dig out my system pressure guage and see if I have a fitting which will fit the fuel rail. That may tell the storey better.
1995 993 coupe
2012 Boss 302
Old 08-09-2005, 03:12 PM
blue82coupe's Avatar
Bill, are using the cis fuel pump and did you retain the accumlator? My car does the same thing.I removed the accumulator and used the hi pressure cis pump. My engine is from a 95 993. Could it be that the regulator is bleeding pressure between starts because of the 100psi or so pump? Dan
I have plenty of lead for my pencil... just not enough paper to write on..
82SC with 95 993 engine
2004 Ford Powerstroke
Old 08-09-2005, 03:31 PM
Insert Tag Line HERE.....
rattlsnak's Avatar
Mine does the same thing. I also have no Accumlator. One of these days Ill put one in. I just ran the fuel line right from the pump directly to the fuel rail. Once I start it, it will be fine for the rest of the day. But the longer it sits, the longer it takes to prime. Usually no more than 15~20 seconds of cranking though.
Marc
Old 08-09-2005, 07:52 PM
david.avery's Avatar
Are you using the tired starter from 1980?
Years ago I had to go with a High Torque starter for mine to fire properly.
David Avery
05 Lotus Elise (sold) | 08 BMW 135i
visit FocusedE, my e-business company | visit Spyderclub
Old 08-09-2005, 08:05 PM
You do not want an accumulator, mine has the cis pump, I vaguely remember that some cis pumps may have had a check valve on them. Have to do some research on that.
Bill Verburg
Old 08-10-2005, 06:11 AM
tholyoak's Avatar
According to the factory manual the following could result in a hard to start car
Idle speed contact short to ground or break
Engine temp sensor II
Idle speed control activation
Faulty DME
DME relay
Tank venting valve
Injection Valve
Fuel pressure
Intake leak
ground and plug connections
speed/ref sensor
ignition system and output stage.
You need to hook up the fuel pressure gauge and see how long you maintain residual fuel pressure. The factory spec is after shutting down the motor the residual pressure should be 3.8 bar, and the max drop in 30 min should be 0.5 bar. As Bill said with the CIS pump there is a check valve in the pump output that can be the culprit if the pressure is not remaining after shutdown.
Todd
1989 911 Targa
Old 08-10-2005, 07:33 AM
Todd, thanks for the list ... thats a lot of good stuff to check.
I also just got an email back from timmons. His first suggestion was the fuel check valve. quite frankly, I don't know if my '88 even has a check valve... but I'll look into it.
Old 08-10-2005, 09:42 AM
Administrator
Jack Olsen's Avatar
As a data point, my 1993 motor starts right up no matter how long it's been sitting. I have a 964 fuel pump and (although it shouldn't matter) a high-torque starter.
Old 08-10-2005, 10:47 AM
Mine does the exact same thing. Nature of the beast I guess.
Mike
89 Carrera 3.6 V-ram #94
Livin' for Targa time!
Want to make God laugh?
Tell him your plans!
Old 08-10-2005, 11:09 AM
