PorscheGuy79's Avatar
Porsche Crest Roll Bar questions
I am looking to install a roll bar for my car. I do quite a few DEs and feel that its worth while. I would love pictures of people who have them to get an idea. I like the bolt in but I wouldnt mind hear both sides, as well as testimonials. I was also wondering which have the diagonal side bars for side impact. Once again pictures would be great.
Thanks!
Matthew
“Sometimes the questions are complicated and the answers are simple.”
Old 08-09-2005, 08:31 PM
billyboy's Avatar
sweet roll bar
I just put in a bolt in race type of 2" DOM tubing. Easy instal and really stiffins up the car. Definitely an upgrade!
'68 911 2.2 "E" PMO Carbs, Electromotive Crankfire Ignition, Adjustable Spring Plates, turbo tie rods, Bilsteins, headers, MB911 muffler...
"The sea merely lies in wait for the innocent but it stalks the unwary."
Old 08-09-2005, 08:40 PM
leverpuller's Avatar
I'm running 22mm ft and 20mm r big diff from the stock 20 - 19
Old 08-09-2005, 08:43 PM
porsche guy I forgot to tell you that i'm running bilstien sports and front strut brace, the car is lowered to euro height ( inhale )...... and 7in fr, and 8in rears bbs 2pc rims on my 82 coupe
Old 08-09-2005, 09:11 PM
Sameer's Avatar
check out
www.das-sport.com
Speed Yellow 911 Ruf BTR Conversion
PCS Membership No: 266
Rennlist Membership No: 050315-5911
Ebony Black 2004 Jaguar XJ6
Titanium Grey 2003 Ford Focus
Old 08-09-2005, 10:04 PM
Noel's Avatar
I have the Das-Sport bar in my car and really like. It was fairly easy to install, but if you have the early 80s factory sport seats, then it will interfere with sliding the seat back all of the way.
Gone but not forgotten -
1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C
Old 08-10-2005, 04:25 AM
IROC's Avatar
I have an Autopwer bolt-in roll bar. I think it is a good addition for a DE-type of car. The back seats are now useless, of course, but that's the trade off. I don't think my roll bar stiffened the car at all but that's not really what I was after.
You're not going to get "door bars" generally with a roll bar - those come with a full cage. IMHO, a full cage is too much for a street car.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
jdowty3's Avatar
I also have an Autopower bar and modified a pair rear seat backs to clear the side bars. The only issue is that the seat backs were from a coupe and don't have the lock pins required for a Cab to keep them upright. My daughters ride in the back seats a lot so I don't have the cross bar. I definately think it stiffened the body flex inherent to a Cab.
Jim Dowty
97 911 Coupe (Forest Green metalic, sunroof, leather)
PCA RSR region Insurance chair and Board member
Gruppe B #309
Old 08-10-2005, 05:13 AM
Re: sweet roll bar
Can I get more information on this?
Matthew
Old 08-10-2005, 06:19 AM
billyboy's Avatar
rollbar details
MIne is an AutoPower also. It has the welded in diagonal brace.Of course,I have no way of testing for added rigidity and it is purely subjective, but on my first test ride, it sure seems like there is noticeably less body flex
Old 08-10-2005, 07:30 AM
I would rather be driving
jpnovak's Avatar
I have a OG Racing setup. It sits high on the sills and allows the seat to go all the way back with no problem. That is good for my 6'3" frame.
Old 08-10-2005, 07:51 AM
Matthew -
I am using the Das-Sport bolt in bar in my 930 and really like it. I am in Chicago so if you are ever around you can feel free to come by and take a look first hand. Unfortunately it is a difficult item to get a good installed picture of.
Rob
Rob Montgomery
'88 Blk/Blk 930 ('Lucy') - Not Stock & Not Running
Old 08-10-2005, 07:57 AM
Looking between the Saftey devices with a fixed diagonal and the DAS Sport, I see one big difference. The SD comes powder coated from the factory while the DAS is unfinished. Is this true, anyone have experience. I think it would be much easier to have it come ready to rock rather than to have to paint or powder coat it.
Matthew
Old 08-10-2005, 05:12 PM
curmudgeon's Avatar
The DAS weekender definately comes unfinished. Just got mine last week. I am still awaiting a reply from DAS to see if they recommend mounting the shoulder belts directly to the bar.
1983 911 SC
2006 Cayman S
Old 08-10-2005, 06:34 PM
billyboy's Avatar
my autopower came painted black but scratched
Old 08-10-2005, 07:04 PM
matt,
the "bird version 3.2" has an autopower bar in it... did you take a look at it when you were at kevin's? i think these things come up pretty cheap used. not a bad 'de' solution IMO.
-bernie
Old 08-10-2005, 07:45 PM
Jeff Alton's Avatar
I have DasSport sittin in my garage. Heavy! I like the design of the OG one better as it mounts higher up and is probably a little bit lighter as well. I might sell it and get he OG one......
Jeff
www.turn3autosport.com
Old 08-10-2005, 08:25 PM
Originally posted by einreb
matt,
-bernie
The only reason I look to something else is because they bolt to the weaker floor from what I heard. The others are mearly bolt in.
Matthew
