Heat exchanger vs headers
This may be a stupid question. What is the difference between heat excahngers and headers. Is one more favorable over another. I live in Florida so heat inside is not necessary.
Any advice would be appreciated
Mike
75 911S
Old 08-11-2005, 05:11 PM
RETIRED
Joe Bob's Avatar
Headers are cheap....heat exchangers are not....if you don't need heat....go with headers....
Headers usually have a larger diameter and let an engine breathe better....but stock engines actually like stock exhaust....
2012 ML350 3.0 Turbo Diesel
Old 08-11-2005, 05:17 PM
MBruns for President
JeremyD's Avatar
Where in Florida are you mikey?
Old 08-11-2005, 05:30 PM
Bill Verburg's Avatar
Some heat exchangers, like SSI & B&B are headers with heater boxes wrapped around them
Here is a pic of SSI w/ one of the heater box covers cut away
Factory exhaust '75 -94 is also a header w/ a heater box wrapped around it, it's just not the optimum design to take advantage of any 5 th cycle effect that may be present
here is a 964 header w/ heater box cut away
Bill Verburg
Old 08-11-2005, 05:47 PM
Do heat exchangers help with heat removal vs. headers? I don't know if my question makes sense.
Do headers allow exhaust heat to remain in the vicinity of the engine, whereas HE use fan air to duct it away?
Tom
'71 911 T Targa (Sold )
Old 08-11-2005, 06:08 PM
JeremyD's Avatar
Nope - just help you keep your tootsies warm in those cold climates...
Old 08-11-2005, 06:30 PM
WydRyd's Avatar
If you don't need the heat because you live in a warm climate all year round, replace the heat exchangers with stainless steel headers.
Headers would weigh a lot less too
Merv
'89 911 Turbo Cab
Protomotive MAP ECU, Twin Plugged Heads, GT2-EVO CAMs, 3.3L fully finned P&C's, ARP fasteners, C2T head gaskets, Titanium Retainers, Turbo spec valves, springs & guides, 964 splash valves, GT35R BB turbo, GSF Stainless Headers, Magnaflow Exhaust, Full bay Intercooler, TiAL 46mm w/gate, TiAL 50mm BOV, Apexi AVC-R EBC, SPEC Stage3+ Clutch kit, Crane CDI Ignition
Old 08-11-2005, 07:27 PM
Steeve's Avatar
So allow me to add my ignorance to this post. I live in Houston, so I have an abundance of heat. Is everyone saying that I have heat exchangers that I can replace with headers, and I will benefit from this swap?
Thanks!!!
'86 911 targa
'04 MB 230K Sport (daily)
Old 08-11-2005, 07:30 PM
JeremyD's Avatar
Headers (B & B) with integrated HE's
Old 08-11-2005, 07:33 PM
drag racing the short bus
dd74's Avatar
Thanks!!!
Probably - but headers for a 3.2, IIRC, are big bucks, compared to those for a smaller engine. Bursch makes a header for the 3.0 and under that is fairly reasonable.
Old 08-11-2005, 08:57 PM
dd74's Avatar
Steve in Houston - if you're interested, you might want to see what Michigan Mat is selling...
3.2 B&B Headers + Muffler + Oil lines - $1500
Old 08-11-2005, 09:03 PM
gerard vaglio's Avatar
Heat exchangers are the stock exhaust that came with your car, it's an exhaust sytem that also allows you to have heat.
Headers can come with or without the heat option but headers are generally considered a high performance exhaust system made up of equal length exhaust tubes that allow the exhaust pulses from pistons to exit without getting in each others way.
Ideally, this produces more hp, say, 10-18hp on a 3.0 for example.
Was that your question?
Old 08-11-2005, 11:53 PM
coolcavaracing.com
Kroggers's Avatar
Send a message via Skype™ to Kroggers
So, is the SSI's heat exchangers or headers with the heat option??
Pål (Paul) - The Norwegian lost in Finland...
1978 911SC 3.6 | 2001 Boxster S Racing Car | 1966 912 based 911 RSR replica racing car (for sale!)
come and follow the Porsche Sports Cup racing fun and me at www.facebook.com/coolcavaracing
Old 08-12-2005, 01:24 AM
Does not installing the heat exchangers also eliminate use of the defroster? It does rain alot in Fl. Thanks for all of the tips.
mike
911s
Old 08-12-2005, 04:42 AM
Did you read post #4 above? A heat exchanger is just a sheet of tin wrapped around a set of header tubes. Cabin air is pumped through, absorbs heat and continues to the chassis.
Bill Verburg
Old 08-12-2005, 05:40 AM
coolcavaracing.com
Kroggers's Avatar
Yes i did read it, but I am Norwegian - I drink Beer and do all the other normal viking related activities . Understanding the written text is not an important part of my day-to-day needs! I will try to refrain from stupid uneducated questions in the future
Old 08-12-2005, 05:48 AM
Senior Member
Thanks!!!
Steve,
You may not need heat but how about defrost in the winter? Insides of the windscreen get misty or need clearing? I thought I did not need heat either (Phoenix is rather warm most of the time) but there are times during the fall and winter when the windows need clearing and a touch of heat sure helps.
Get some SSI's or B&B's and you have the best of both worlds.
Joe A
Old 08-12-2005, 06:30 AM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
You can buy inexpensive headers for any displacement motor and in a variety of diameters, not just for 3.0L and under. Price generally depends on the grade of materials being used. These are 1 5/8" OD mild steel headers with adaptor pipes for a street muffler that have been ceramic coated inside & out for under $600.
Headers made in higher grades of stainless steel (T304 or T321 for example) will be much more expensive.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 08-12-2005, 06:33 AM
Designer King
Paulporsche's Avatar
Tom,
Heat exchangers actually DO help with removing heat from the engine. One trick to help keep the engine cooler in summer is to pull up on the red levers just a little which will dump some heat from the engine compartment without heating the cabin.
Mike,
If you don't have heat then you won't have the type of defrost that actually melts frost (like we need up here in winter). However, if you just need demisting you may be OK w/ just the fan blowing ambient air.
Pal,
Don't be afraid to ask "stupid" questions. Everyone's got them. A few "stupid" answers have been posted too. Don't ask me how I know.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 08-12-2005, 06:36 AM
Are there any effect of run headers with a 2.4 MFI engine? Backpressure?
Derek Oxford PCA - Nationally Certified Instructor
2002 Boxster S ( race car)
2010 LR4 2009 GMC Sierra (Porsche Support
2011 M3 4Door
Old 08-12-2005, 06:43 AM
