where do people put crossovers?
Hi,
I've just bought a pair of MB Quart Reference 6.5's, and don't know where to put the crossovers. I read one post where a guy just put them in a plastic bag with zip ties and put them in the doors. But looking at the design of the crossovers, i don't think the electrical components would last long with the slamming of the doors all the time. Any ideas? And also while i'm posting, My speakers say power handling 60-120w RMS. My head unit is a Pioneer P1, so it has inbuilt amplification of 60w RMS. Is an amp required? I have a kenwood amp that is 110w RMS x 4, but it will be a hassle to wire in. And will there be a noticeable change in quality?
_____________________ '73 RSR Interpretation ---------------------------------- Last edited by StayGold808; 08-16-2005 at 04:53 AM.. |
Mine are in plastic and in the doors, but they're held in place w/ a good wad of metal roofing mastic. They've been there going on 3 yrs, and no issues, and were tight this weekend when I was tracking down a rattle.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
i also have a pair of infinity kappa 4x6 comming for the backs, but i think i'll just mount the crossovers for them in the rear...
_____________________ '73 RSR Interpretation ---------------------------------- |
The P1 puts out 60W RMS x how many channels? If it is 4 channel you could bridge to 2 channels for more power. Are you sure the speakers aren't 60W RMS, 120Peak?
If you have to drive the P1 to max to power the speakers sufficiently, your distortion would likely be higher than if you used your 4x110 kenwood. I say hook it up and fool around without the amp first. If you blow a fuse or it sounds like poop, you know you need more power.
-Matt 1985 Targa |
Virginia Rocks!
Under the wood in the passenger floorboard. It was a tight fit because they were oversized.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na Guards Red is for the Unoriginal
In the doors, I made a foam cradle for them.
it just says power handling 60-120W.. i don't know if thats RMS.
The P1 is 60WRMS x 4. But its a shame not to use its preouts, 5V! I read somewhere that underpowering good quality speakers runs the risk of melting the coils, because your using volume to make up for the underpower. But the head unit is 60W RMS x 4, so its peak is probably around 100w potentially right? So then wouldn't it be much the same amplification from both?..
UFLYICU
Match the RMS power, ignore the peak. Peak is momentary power only, and really means nothing with respect to the quality or power of the system.
_______________________ Racer Rix Spec911 #5 prc-racing.com |
60-120 ==>60 RMS, you should be fine with the P1's 4x60RMS. The kenwood puts out more power than you need, you could still use it if you want. Like zoanas said, amtch RMS and you'll be fine.
-Matt 1985 Targa |
like JO - I wrapped mine in foam sheeting and put them in the doors
- not sure if it might help to keep them close to the speakers, but I did that anyway.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I installed them inside the door storage area way foreward under the handle.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
MB Quarts love to be driven, install the amp too. Your midbass notes will be appreciably cleaner. You don't want to bridge the stereos output, bridging is good for amps that drive subs, not fullrange; too much distortion. Turn the gain on the amp about 75% to start.
Donnie Currently Porsche-less.....
Maybe this has been covered to death in other threads, but how successful have people been in noise dampening the engine compartment?? Seems to me it would make upgrading sound systems alot easier..
T
"Todd" 98 Tahoe ,2007 Saturn Vue 86 930 black and stock, 80 930 blue tracdog 91 Spec Miata (yeah I race a chick car) "life"ll kill ya" Warren Zevon |
