Porsche-poor's Avatar
Engine drop question
In the 101 projects book project number seven, step 4 and in the Bentley book page 101-5. What purpose does the removal of the clutch positioning lever serve? Does this need to be done to get the engine/transmission out of the car or only if the two plan to be separated.
I may need to do a drop to fix some oil leaks but have no plan to separate the engine from the transmission as a new clutch was put in when I bought the car.
'79SC Targa
'2021 CRV
Old 08-16-2005, 07:24 AM
Rick Lee's Avatar
If you don't plan to separate engine and tranny, then you can leave it alone. If separating, it's a lot easier to do this stuff while it's still in the car than once it's on the ground and you can't get underneath it anymore.
2022 BMW 530i
2021 MB GLA250
2020 BMW R1250GS
Old 08-16-2005, 09:06 AM
Scott R's Avatar
I decided to replace the clucth after I had the engine out, and removing the helper spring, and lever sleeve was not terrible on the floor, but I waited until I had the motor back in to re-install it.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 08-16-2005, 09:17 AM
Thanks guys. Just the news I need. THe fly wheel, bearing, pressure & clutch were done just lat year so I have no need to split it now.
'79SC Targa
'2021 CRV
Old 08-16-2005, 09:36 AM
