Porsche-pa
75Carrera's Avatar
What's that hole for?
In the front boot of my 75 911 Carrera, under the carpet on the passengers side is a lid opening down to a fairly decent little box area. At the side where the steering comes through (about midships in the car) there is a large tube like opening (est. 3-4" across) coming up from the bottom that is covered with some sort of cloth. What the hech is that for? I don't have air cond. if that's a factor. Could be blocked off from years ago when it was stripped down and painted and maybe not removed afterward?
Current Garage:'04 996TT S Cabriolet, 1975 911 Carrera 3.2 powered (my Precious),
Also rans...
'02 996TT, '03 996TT, 1967 912, 95 993 C2 Cabriolet, 76 911S Carrera, 2014 Carrera S, 2014 Turbo S, 1999 AMG SL, 1966 Lotus 7,
Donny
Old 08-18-2005, 01:43 PM
Bill Verburg's Avatar
It's called a smugglers box, some folks like to move their battery there, others put their stereo amps in there, others come up w/ their own creative uses
Bill Verburg
Old 08-18-2005, 01:49 PM
RETIRED
Joe Bob's Avatar
Mine has A/C stuff in it....or what's left of it....
2012 ML350 3.0 Turbo Diesel
Old 08-18-2005, 01:51 PM
techweenie's Avatar
The tube like opening, I believe, appeared when factory air started to be an option. It was on all the cars from thet point, AFAIK.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 08-18-2005, 02:00 PM
and some of the older cars had a gas heater in it
Bill Verburg
Old 08-18-2005, 02:03 PM
Porsche-pa
75Carrera's Avatar
Thanks guys. Should it be sealed off so no dust penatrates the "smugglers box"? The cloth allows fine dust in.
Bill,
Seriously? I was pretty sure from the way some of my old P-cars smoked it was for applewood or coal storage....
Also rans...
Donny
Old 08-18-2005, 02:09 PM
There should be a drain hose that routes through the smuggler's box from the air intake plenum to the ground. If not complete, rain/wash water will collect in this area.
Sherwood
Old 08-18-2005, 02:17 PM
Porsche-pa
75Carrera's Avatar
I was just thinking Mr. Verberg, with that amazing new "track machine" you've just gotten how is you have time for this Pelican stuff? If that sweetheart were sleeping in my stable I'd be out there letting the reality sink in and stroking every inch of her, hell, I'd probably sleep in it (at least the first week or so). Again congrats!!!
Also rans...
Donny
Old 08-18-2005, 02:32 PM
pa911's Avatar
I,m glad you said "track machine"
Old 08-18-2005, 02:44 PM
techweenie's Avatar
Yes, I believe there's a plastic cover for that.
1969 coupe hot rod
Old 08-18-2005, 02:51 PM
