Fluidyne front Oil Cooler How to install?
I have a Fluidyne oil cooler which i would like to install in my car. I have a '76 with a 3.6 (993) engine. I heard that some people are running this coolers, but i am not finding a way to make it fit under my C2 front bumper?
has anyone installed one of this before? Any hints, pics, etc??
Thanks a lot
Mario
'76 911 w/'97 3.6 Euro Vario Engine & Turbo body kit & TPC Supercharger
'15 GT3
Old 08-17-2005, 05:38 PM
Here's how I mounted mine under the front bumper cover...
Old 08-17-2005, 05:42 PM
What type of coolers are those?
Also, the bumper bar is it a stock piece?
Mario
'15 GT3
Old 08-17-2005, 06:26 PM
Oil coolers are Mocal with -12 fittings...yes, the bumper bar is the stock item.
Old 08-17-2005, 08:23 PM
MyTurbo3.6,
I've got to say.... "nice freakin job"
boy that is just great!
are they in series or parallel?
brant
914/6 2.0S with twin plug
all metal body panels
19quarts of oil
4 gallons of gas
and 1826 lbs (wet)
Old 08-17-2005, 08:51 PM
This is the one that i have. Has anyone installed one of this under a C2 bumper?
Mario
'15 GT3
Old 08-18-2005, 05:11 AM
Bill Verburg's Avatar
Does it have any mounting tabs?
Bill Verburg
Old 08-18-2005, 05:13 AM
Yes, mine actually has monting tabs in each of the for long sides?
Mario
'15 GT3
Old 08-18-2005, 05:30 AM
Then it will go something like this
Most of us are using a B&B but the fluidyne appears to be similar.
Bill Verburg
Old 08-18-2005, 05:38 AM
The problem is that the Fluidyne seems to be much wider. How much of a gap should I leave between the cooler and the panel where it is mounted?
Mario
'15 GT3
Old 08-18-2005, 06:10 AM
Thats a per isnstallation decision
When I did my B&B we mocked it up so that the cooler was as far forward into the spoiler as possible. Turned out that the spoiler itself was used as the lower mount and some tabs were welded to the chassis for the top. You'll need to mock it up, do a trial fit, measure then weld and install. It will help cooling to seal around the edges and have a reasonably large exit space. Muffinman(Rob Fussi) put a bigger B&B and had to use an RSR type pan inthe spare wheel well
Rob's install is detailed here
Bill Verburg
Old 08-18-2005, 08:02 AM
fireant911's Avatar
MyTurbo3.6,
What can you share about those parking lights? Are those pieces that you fabricated or purchased?
Daryl G.
1981 911 SC - sold 06/29/12
Old 08-18-2005, 10:20 AM
