How to remove chrome from wheels?
I have a set of Design 90 wheels that where chromed and it's coming off in places. What is the best way to remove the nickel?
So far the best ideas are acid dipping or light sandblasting.
Do you know better?
Old 08-16-2005, 02:00 PM
Elu Elu is offline
Elu's Avatar
Send a message via Yahoo to Elu
I've only heard of acid dipping working for chrome removal. Are you going to have them re-chromed or painted?
Come check out my new stuff....you know you want to.
www.myspace.com/elu
Elu - the sensual nature of humanity
Available on Eroica Records
The new album is now available.
Old 08-16-2005, 02:33 PM
Unregistered
sammyg2's Avatar
Acid or a big-a$$ grinder.
Old 08-16-2005, 03:39 PM
Bird. It's the word...
Fishcop's Avatar
I had the chrome removed from fuchs (idiot PO) by taking them to a chromer where they reverse the polarity in the bath... basically it dissolves the chrome from the wheel gently.
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 08-17-2005, 03:39 PM
Fishcop..That sounds likea better idea. I'm going to ask about that!
No I'm not going to rechrome them. I will either powder coat or Wurth wheel paint.
Old 08-17-2005, 04:28 PM
When I bought my TL Cab 1987, the wheel came with chrome and now starting to peel off, I really want to remove the chrome and make the wheel look like polish, but do know where to start.
Still looking for shop in the Bay Area to have it done, possible cost a huge $$$$$
911 1987 Triple Black Cab Turbo Look >> weekend car
SPF MK III Shelby Cobra 427 550HP >> thrill for speed
BMW 88 635CSi daily drive
BMW 87 325i use for rainning day (donation)
Benz 06 E350 use for pick-up kid on car pool day
Old 08-17-2005, 05:17 PM
Yellowbird RS's Avatar
Sodium hydroxide at 8-12 oz/gal (w/v) works well for electrostripping chromium from carbon steel substrates. The bath can be operated at ambient temperature or higher, at a current density of 0.25 - 1.0 amp/sq.in. The fumes evolved are toxic and must be evacuated and scrubbed. The bath starts out as a simple solution of caustic soda but acquires an increasing component of a hexavalent chromium compound as the metallic chromium is electrostripped from the workpieces. The spent solution is hazardous waste and must be properly disposed.
X/A
Old 08-17-2005, 05:26 PM
Yellowbird RS is that process done by a commercial chrome plater or is it more specialized than that.
Old 08-17-2005, 05:31 PM
The wheels are design 90 and are aluminum. Will the same process work?
Old 08-17-2005, 05:32 PM
That's the commercial process.
For aluminim you may use silver glossy anodize
X/A
Old 08-17-2005, 05:41 PM
alfizzo's Avatar
i wouldnt use caustic for stripping aluminum rims. the way anzures posted is for steel. the chrome can be quickly removed with hcl then nitric acid can strip the nickel and clean up the aluminum. however i dont think you are a plater and have access to these chemical or have the means to dispose of the hazardous waste. your best bet is to have a professional do it and pay for it or do it your self and send the toxic waste down the drain or to a landfill. its rather funny how most people approve of tougher enviromental laws but when it has to come out of their pocket they are always shocked on how much it cost and try to find way to avoid paying. its no wonder china has killed so many manufacturing companies in the usa.
Old 08-17-2005, 07:11 PM
Alfizzo I wasn't even considering doing this myself. But I agree with your point.
Old 08-18-2005, 04:12 AM
scottb's Avatar
If your wheels are anything like Fuchs, it's possible they'll be pitted once the chrome is removed.
1984 Targa
Old 08-18-2005, 08:15 AM
techweenie's Avatar
Most of the wheel refinishers will do this. I know Wheel Enhancement does, but I'm sure there's somebody closer. When the pros do it, the wheel surface is left undamaged.
techweenie | techweenie.com
Marketing Consultant (expensive!)
1969 coupe hot rod
2016 Tesla Model S dd/parts fetcher
Old 08-18-2005, 09:18 AM
