stefang's Avatar
Oil line removal
So the oiltank to thermostat line started spewing oil all over the place last week (just in time for me to miss a track day ). Got the pelican package today with the new line and the oil line wrench.
As I'm yanking away at the fitting trying not to bend the thermostat, I'm thinking - sure would be nice to better grip on this thing (not too much room and you have the wrench at an angle). So I have a thought I happen to have a 36mm socket lying around, the impact wrench is already out from removing the wheel nut (CV joint boot). Out comes the sawzall . 2 min later the oil line is sitting on the floor, a couple of shots with the impact gun and YEEHAW - we're in business.
The new oil line looks very pretty.
Stef
Old 08-23-2005, 05:53 PM
Bill Verburg's Avatar
You need to be careful w/ that method. Sometimes the t-stat threads come off w/ the nut.
Bill Verburg
Old 08-23-2005, 06:05 PM
stefang's Avatar
Well, I guess I got lucky then. Still, I 'd decided that a couple of hits with the impact gun set on low torque was better than yanking on the fitting hoping that I didn't bend or break anything further down the line.
Stef
Old 08-23-2005, 06:17 PM
Bland
unclebilly's Avatar
Yup, it's a biotch when the tStat threads come off with the nut but I was able to fix mine...
Old 08-23-2005, 06:28 PM
Brother's Avatar
A relatively safe method is to use a cut off tool to cut the nut. Then use an impact hammer to push the bolt apart and away from the threads. Still leak free 4 months later.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 08-23-2005, 06:32 PM
ianc's Avatar
Yep, you're better off removing it slowly, by hand.
I did the cut the line and impact method, but I lost about half the threads on my t'stat. Luckily there were enough left to seal!
At best, use the impact to just break it loose, then oil and back and forth by hand the rest of the way,
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 08-23-2005, 06:49 PM
