On a crab'd 3.0...how much backfiring is "normal"?
Ok when I drive my car in the morning, I start her up and let idle at 1500 rpm for about a minute.......
Then I start driving, and she will fart fat ones for about the first 3 to 5 minutes of driving, then she settles down ..........also if I gun her and then down-shift she will fart quite a bit......... My heat-exchangers are new ssi's so the problem is not there...Also TRE did a rebuild on the carbs. Keep in mind that in order to run carb's on a stock 3.0, they need to be run rich. Is this normal behavior? thanx, SvK
SvK 1996 993 1968 911L 3.0 Carb'd.....(sold) "I don't even know enough to know that I don't know." Last edited by svonkampen; 08-26-2005 at 06:58 PM.. |
Bob Tilton,
Does your car do this? SvK
SvK 1996 993 1968 911L 3.0 Carb'd.....(sold) "I don't even know enough to know that I don't know." |
Nobody
tansplanting the heart of a beast will involve dialing in little nuances over the course of time as you re-adjust to a new organ.
i had this issue and several others which took about 1000 miles to resolve. my back firing was the result of a lack of back pressure due to the dansk duel out sport muffler. i replaced it with a single out dansk and the problem was solved. in re: to start-up, the carbs need about 30-60 seconds at 1500 rpm to clear its throat(s) first thing in the morning. it's fine once i take off. all other start-ups are fine. have you cked for exhaust leaks? i had one at the SSI flange to the muffler flange. Resolved with new gaskets. how's your engine temp? |
Bob the surgeon ;-)......thanx for responding
my engine temp gauge is always super low.....maybe broken? btw, I have single-out Dansk....will check muffler gaskets.... SvK
SvK 1996 993 1968 911L 3.0 Carb'd.....(sold) "I don't even know enough to know that I don't know." Last edited by svonkampen; 08-26-2005 at 07:55 PM.. |
"in re: to start-up, the carbs need about 30-60 seconds at 1500 rpm to clear its throat(s) first thing in the morning. it's fine once i take off. all other start-ups are fine."
So when you drive to work and leave car for 8 hours, then start up for drive home,,,,no back-firing? SvK
Nobody
yes - i recall from your pics that you had a single out exhaust.
what you did was a major upgrade with a lot of things done at once. 99% of the work has been completed and only time will tell what that 1% needs to be done. sounds like it just needs some fine tuning which is to be expected. what are your thoughts on the suspension? |
Love the suspension.......she is so stable at 110mph........you gonna upgrade?
SvK
Nobody
yeah - all other start-ups are fine after the morning start-up which is also combined with a couple days of sitting. it was much like my '83 rx7 which required the same start-up procedure.
drag racing the short bus
"Crab'd" In this case, I suggest you take your car to one those free clinics; not TRE...
Nobody
i can't justify the susp upgrade right now considering everything is new "down there".
my next upgrade will be a LWB ST replica.
Wish I could give you more feedback on suspension.....I am not a schooled driver YET....so I take it pretty easy in turns........But like I said , Night and Day difference at high-speed..
BTW Dave at TRE said: "The '68 suspension was just plain awful" SvK
SvK 1996 993 1968 911L 3.0 Carb'd.....(sold) "I don't even know enough to know that I don't know." Last edited by svonkampen; 08-26-2005 at 08:57 PM.. |
I think that includes the prior year as well.......
ST huh ?
" ST/GT was permitted to run an oversize engine for racing in Group 4, the FIA allowing Porsche to increase bore but not stroke. As a result, displacement was up to 2247cc, bore having been stretched by 1mm (to 85mm), stroke remaining unchanged at 66mm. Designated Typ 911/20, the highly tuned engines were equipped with twin-plug heads, camshafts from the Carrera 6 and special Mahle pistons." wow.......what color? ;-)
ST rear...for Surgeon Bob,
Nobody
these are my initial thoughts as i have just been having them within the last few days:
1 start with a carerra and backdate it 2 69-73 front fenders 3 plain front bumper (not split S or RS) 4 1 piece rear bumper 5 fuchs up front, minilites in the rear 6 cibie hood lites (2 pair) 7 RS interior with dark green leather 8 slate grey exterior 9 no decals this would require selling my car and starting new. |
it will be interesting too see what your car will fetch.....but how will you live without a working Porsche during the build?.....that is just torture. Just a mere 6 weeks without my ride and I was ready to start Prozac...
SvK
SvK 1996 993 1968 911L 3.0 Carb'd.....(sold) "I don't even know enough to know that I don't know." Last edited by svonkampen; 08-26-2005 at 08:52 PM.. |
DD74,
heheheehehe...i couldn't figure out what you were talkin' about "crab'd" ....free clinic ! hahahaha ....but my car is suffering IBS ;-) SvK
So, umm... What happened to the CIS injection that came with the 3.0? You could always 'uncrab' yourself...
ianc
BMW 135i. Nice. Fast. But no 911... "I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79 |
all below depends on ignition, cam, etc.
the gas has to be in a state for efficent combustion. CHT becomes a factor with a rich idle circuit. I've found that a very rich circuit needs a bit higher CHT than just a rich circuit to preventing start up bs. Very rich needs about 175degF for no bs at all, rich needs about 160degF.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ronin,
I have no idea what you are talking about ;-) Please speak english...so this dummy can understand........ SvK
