hi.. i need help from you guys please, my 1979 porsche 911 a/c wont get ice cold. i put 2 cans of 134a, and the system wont take 3 cans, it gets up to 60 degrees only, no cooler than that, what can i do to get 45- 50 degrees 3 cans will make it blow hot air, i have to remove a can a total of 2 cans only also front condenser fan not working is that stoping it from getting cold what can i do thank you for the help.
sylvester |
Do a search on AC. There are lots of threads that go into great detail on this subject.
1986 Carrera Coupe 1999 Chevy Tahoe 1987 Chevy Blazer 1955 Chevy Apache 3100 Pickup "A little knowledge is a dangerous thing" |
Detached Member
Not an expert, but do a search on Jim Sims and you'll find everything you want to know about pcar A/C. Your in Houston so its hot and muggy, you may only get 60 degrees. Are you using gauges? Its possible to overfill you should be getting 19-30 psi on low and 210 to 300 on high side. Search on "A/C Pressures" and you'll find Jims numbers. I thought mine was working OK, but at 105 today, I'm barely getting 48 degree vent temps, I want in the 30's, Jim suggested that I bleed out some 134a. I did a little and may try bleeding some more.
Hugh |
sylvester, I suggest you try John at Cool Flow (713-688-7525) in Houston near 610 and 290. He spent a couple plus hours (and only charged me for an hour) to adjust my system a year and a half ago. He's been in business since Packard installed ACs in their cars.
1987 911 Guards Red Targa, nearing 200,000 miles, lowered, 7's & 8's, 964 grind cams from John Dougherty, A.P.E. Mass Flow Sensor with chip to match, cat bypass, strut brace, dual out muffler. Will consider newer model in 8 years when I turn 75 and then maybe not. 2012 BMW 528i (wife's) 2007 Toyota FJ (rain and off road days) |
Large Registered Member
Try replacing the receiver / dryer with a ProCooler. Between that and changing the refrigerant to Enviro-Safe ES-12a, I went from 60* temps at center vent to 35*!! That is with outside air temps hovering near 100*
'85 Carrera Coupe, Marble Grey #118 JP/R6 '93 Lexus SC400, '00 Ford F-150 '70 911T- 2.7 (SOLD) |
Yes, you need the front condensor fan to be working too!
Peace, Ron www.ronorlando.net 78SC Targa 3.2 SS, 964 cams, CIS, SSI's,Dansk Own a gun and you can rob a bank , own a bank and you can rob the world. |
fix that fan..otherwise, stop and go situations will be warm. i second or third the suggestion to try a search..tonnnnnnnnns of info on a/c systems on this board. your r-134 system also deoends on a certain amount of oil..you can actually have 'too much' r-134 in your system and cause it to run warmer rather than cooler. you might consider that..you may need to evacuate and start over. i recommend finding a good tech if you don't have experience evacuating refrigerants.
ryan
To the memory of Warren Hall (Early S Man), 1950 - 2008 www.friendsofwarren.com 1990 964 C4 Cabriolet (current) 1974 911 2.7 Coupe w/sunroof 9114102267 (sold) 1974 914 2.0 (sold) |
