Rough Idle and acceleration ( Help )
Just went to lunch , car was running perfect.
Started it up and now have some surging rough idle and some loss of power with acceleration . Filled up gas tank Saturday and added 3 oz ( as per bottle ) of Lucus gas treatment for valves and cylinders . Driven about 20 miles since filling . Do you think this might cause it or do you think I have other problems ? Fouled plug ?
Help !
Vinnie in Ventura
1989 911 3.2 Silver Anniversary Edt
Old 08-29-2005, 02:58 PM
DW SD's Avatar
There are many reasons this could happen. Vacuum leak (maybe a hose split), plug wire to a cr@p, etc, etc. Fuel seems only one of many possibilities.
Can you give more information that may be clues? Does it rev freely or stumble at a certain RPM? Did you drive though a HUGE puddle? Did it pour down rain, etc, etc Does it behave at Wide Open Throttle?
Doug
1971 RSR - interpretation
Old 08-29-2005, 04:36 PM
No Water . Stumbles at beginning acceleration , then stablizes.
Could it be O 2 sensor ?
Old 08-29-2005, 04:39 PM
GFCC
Jeff's Avatar
Vince, Did this happen at all before you last gas fill up? If not you may have gotten a bad tank of gas (A bottle of octane booster will help that).
Need more info though.
Jeff
1976 911 Coupe w/ Euro 3.0 - Sold
1987 Carrera Coupe - Sold
1999 Carrera Cabriolet - Current
Old 08-29-2005, 04:47 PM
Jeff it was surging at idle about a week ago but stopped .
I added Lucas Treatment 2 days ago and now the problem is back and constant .
Old 08-29-2005, 04:51 PM
GFCC
Jeff's Avatar
Vince, There are a number of things that could be causing this but The #1 place to start is the DME relay (Located under the drivers seat, it is a small black relay). Try puting in a new one of these (you should always carry a spare in the glove box).
The second thing I would look at is the Idle Speed Control Valve. It may need to be cleaned.
Jeff
Old 08-29-2005, 05:10 PM
bento's Avatar
had a similar problem
I had a similar problem for a while which went away at full throttle. idle was bucking and the part throttle response was erratic with a good amount of hesitation. search for the thread i did on the subject entitled (i think) 3.2 Hesitation Problem. It turned out to be a bad injector but I managed to replace much of my ignition system in the process of located the problem.
I suggest the following: DME, then spark plug wires, then plugs (maybe there is one that is fouled), then injectors.
Good Luck
oversteer...there is no substitute
Old 08-29-2005, 05:52 PM
oly oly is offline
1985 Carrera Coupe
vincenza,
Did you fix the problem? What was the source?
Art
Old 08-18-2007, 06:15 AM
