really well done
ECU Doctors has them and recommended Bosch part 0 261 204 376 with Driveblock removed. My research shows it’s for a Tiptronic 3.6. They said it should be an issue because the ECU can sense if it’s a Tip and a Tip has its own ECU.
Anyone know for sure if it’ll work ok with my 915? They said if there are any issues to send it back for up to five years and they’ll make whatever modifications that are necessary. |
The original mg. /44 was better in this respect as it came stock w/ a steel girdle stabilizing the si/o shafts, I also went w/ a /67 for the trans cooling feature but recomens adding a steel girdle here too. |
on a 55 pin DME I think that it is pin 44 that activates tip coding |
If you ever find yourself in San Diego, you bar tab is on me. |
Nice build @plexiform
Thank you both! Drives amazing but now I'm thinking it might be time to see what a modern Porsche race car is like. But sadly prices of modern GT3s are so insane that may never happen. |
http://forums.pelicanparts.com/uploa...1753371804.gif trans is still #42 I think that you need #56 & 82 the tip has a different way to control idle from the manual, I think I recall a TPS and stepping motor on the throttle |
Very clean |
Getting closer… soon to be IROC tribute. Hope to be running next week after ECU comes back from specialized ECU. Then off to paint, wife got to choose one of the IROC colors, she chose Magenta, will see if I can commit to it soon enough. 1982 chassis with 1989 930 turbo G50 torsion tube and trailing arms grafted in.
http://forums.pelicanparts.com/uploa...1753388488.jpg http://forums.pelicanparts.com/uploa...1753388514.jpg http://forums.pelicanparts.com/uploa...1753388587.jpg http://forums.pelicanparts.com/uploa...1753388652.jpg http://forums.pelicanparts.com/uploa...1753388699.jpg http://forums.pelicanparts.com/uploa...1753388730.jpg http://forums.pelicanparts.com/uploa...1753388799.jpg |
Kind of looks like a short hood ST right now but the plan is RSR IROC tribute
http://forums.pelicanparts.com/uploa...1753390499.jpg http://forums.pelicanparts.com/uploa...1753390572.png |
http://forums.pelicanparts.com/uploa...1753716311.jpg
This one has a 3,6 conversion included the 964 gear box and RS92 brakes. |
http://forums.pelicanparts.com/uploa...1755287346.JPG http://forums.pelicanparts.com/uploa...1755287346.JPG http://forums.pelicanparts.com/uploa...1755287346.JPG http://forums.pelicanparts.com/uploa...1755287346.JPG And there is absolutely zero room up top. |
Congrats man! It's in there. Mine is tight like that too. Zero clearance on the vram to go higher.
Your fan scavenge thing is cool looking. Haven't seen that flavor yet. I heavily modified the rennline CF tube on mine but it leaks at the bottom where the exhaust side and it meet at the tin opening. |
Is that the new version of Fabspeed on yours? If so let us know how it sounds, i love my 3yr old console version. |
Any issue with your exhaust bottoming out on speed bumps? Thinking about raising the rear 10-15mm and trying to rotate the exhaust to get a bit more clearance before I just pull it all out and buy a new tin. I want to start this thing! |
It is. I’ll post a video once it’s running. |
This is what my car looks like. It usually only scrapes on steep driveway transitions and the largest speed bumps.http://forums.pelicanparts.com/uploa...1755544399.jpg
After looking at the pictures of the varioram at the 'proper height' with the package tray modified, it would appear you are committing to a partial engine drop to get the intake off the car? I can still get the manifold off the car at the Timmon's height.
Anyone here with the TPC supercharger instead of the Rassant intake? Anyone tried both? |
Can we talk about the 3.2 cross bar and console again? Is the top of it at a different height than the 3.6 cross bar? Anyone ever measured the difference? What is stopping someone from simply removing the spacers and lifting the aft end up the 1.25 inches the spacers force it down? This has been bugging me.
3.6 mount & tin http://forums.pelicanparts.com/uploa...1752966489.JPG 3.2 mount & Sheridan f/g http://forums.pelicanparts.com/uploa...1752966626.JPG w/ a vram a modified package tray is more desirable than the droopy drawer ghetto look which can be ameliorated w/ a custom, read expensive, exhaust setup. just my opinion but since I've had 964, 993 vram & 993 non vram the 993 non vram is the best compliment to the 915 and early chassis. The vram has what I call a Camel hump torque curve, the cammed n-vram is more like a pouncing tiger. You really don't miss the lower rpm vram torque, and you can appreciate the higher rpm tiger torque curve. a 3.8RS is very hard on the 915 in the lower gears. |
Thanks for the pics and insight about the different motors, Bill! I could've sworn my 3.6 tin was all 'inside' the engine cutout, but now I'll have to go look again. If it is, the only thing stopping me from going higher is the V-Ram.
Here is an "old school" version! Forgotten just how old this 3.6 setup is but it came out of Bill Verburgs car at least 10+ years ago and no idea how long it had been running with him! Only change from when I got the motor from him is the B&B exhaust system.
http://forums.pelicanparts.com/uploa...1760968593.jpg http://forums.pelicanparts.com/uploa...1760968593.jpg |
For some reason I thought that it has the aluminum console w/o A/C but I guess not. You'd have a problem using the 3.2 console because of the crank damper w/ 3 sheaves. AFAIK there are no single sheave dampers available these days. At one time there was a 964RSR damper w/ single sheave available but no longer. |
Still offering the correct Fuel line adapters & Hoses for the 3.6 upgrade to most earlier 911 models...... http://forums.pelicanparts.com/uploa...1760979604.jpg http://forums.pelicanparts.com/uploa...1760979669.jpg http://forums.pelicanparts.com/uploa...1760979718.jpg All Hose is E85 Rated and available in plain Black or Braided SS. For info, please do not pm me. My box is Full. Please email me, len.cummings @ verizon.net but without the spaces. Thank you. Len :) |
Here's another set, made for late 911SC..... http://forums.pelicanparts.com/uploa...1760980269.JPG Made before we went to Yellow Zinc plated fittings. Today, everything is yellow, even though it adds to the cost a bit. Len :) |
Ooops, forgot the ".net". Now corrected. Len :) |
I did some research and realized that its been longer than I guessed at. I installed your old 3.6 in the 911 in 2003/2004 and its been running nicely ever since!! Really surprised that its been 22+ years! Guess time flies when you are driving a sweet 911!!! I believe that this is a photo of your engine as it arrived here in Phoenix in 2003. http://forums.pelicanparts.com/uploa...1760982424.JPG http://forums.pelicanparts.com/uploa...1760982424.JPG http://forums.pelicanparts.com/uploa...1760982424.JPG |
| All times are GMT -8. The time now is 09:32 AM. |
